tgv sensor wiring
Discussion in 'General Subaru Discussion' started by joeyrex8, Oct 23, 2013.
  1. joeyrex8
    joeyrex8 Member
    Cottage grove
    so after fixing all the bugs on my car, just waiting on miles for break in before tuned I get a tgv code. long story short is the 3 wires in the passenger side tgv were pulled out of the clip. does anybody know what order in color they go top to bottom??
  2. dhanso312
    dhanso312 Well-Known Member
    Minneapolis, MN
    If no one else responds within the next few hours I can go check my car when I get done with some work here. I'm assuming they're going to be the same as an '05 Legacy GT that is. It may help knowing car/year/such if it is in fact different. Also, is it the TGV sensor or the Motor?
  3. dhanso312
    Minneapolis, MN
    I took a study break.. mine as it appeared to be from top to bottom: Black with blue strip - black with yellow stripe - white with red strip. Hope this helps.
  4. joeyrex8
    joeyrex8 Member
    Cottage grove
    sweet ill check when I get out of work. yeah would of helped if I said 06 wrx
  5. joeyrex8
    joeyrex8 Member
    Cottage grove
    Not the same colors I have a red w yellow stripe , white w red, and black with blue
  6. dhanso312
    Minneapolis, MN
    I might have forgotten as I walked away from my car. I would try it 1) black w/ blue 2) Red w/ yellow 3) white w/ red. I will double check when I get a chance here.
