Things for Sale - Springs, sway, struts, bushings, car audio Just listing a bunch of stuff I have lying around you might want. I have a set of Swift FXT springs off my Forester. I'd like to see $200 + sh for them I have my old, beat up, worn out Forester struts (02, no tophats). They'll work on the car if you need something, but both rear have no gas left and one rear and one front are leaking. They're prime candidates for a Koni insert though. If it is desirable, I could chop and prep them for Koni inserts, but I'd ask a hair extra for the work, although it'd probably save a littel on shipping, lol. Shipping and handling alone will take the struts. I have a oem WRX 17mm swaybar, I think off a 04 or something. I have the brackets for it too. I paid $30, so I just want that back. $30 + sh will get it. I have a lot of stock bushings lying around from my swap to Group N, Kartboy, Whiteline bits. If there's an interest, let me know. I have some car audio stuff as well. I have two subwoofer boxes, both for 12" subs. One is a 1.5 cu.ft. sealed box. It's made with 3/4" MDF, lots of screws, lots of glue, and a bead of silicon everywhere and uses a cup style spring clip wire connector and is wired for DVC (two sets of + and - wires inside the box). It's uncarpeted. I do have spare carpeting and can carpet it if that is a deciding factor. It would be in a medium gray though. I'm just looking for cost of hardware really, so $20 + sh will grab it. The second box is a 2.6 cu.ft. ported box tuned to 26Hz. This one is carpeted. Again, it's wired internally for DVC. The wiring just passed through the box and a length of wire to connect to the amp as well as a quick disconnect for easy removal is included. It has lag bolts for tie-downs for the rear cargo area. This box is carpeted in a medium grey felt and again constructed of 3/4" MDF, lots of screws, lots of glue, and a bead of silicon everywhere. This ones a little bigger with more into it, so I'm looking at $40 + sh. I have a single Adire Extremis woofer, 8ohm version. I had two, but one was damaged in shipment. If you're familiar with this, I shouldn't have to tell you anything. For those that aren't, it's a little monster of a woofer, xbl^2 motor, 12mm one way xmax, quite a little beast. I used a pair in a 2-way setup for a while, but they are better suited for midbass duty alone or as a small subwoofer setup. Now only having one, I don't have a lot of use for it plus I've stepped to a larger midbass woofer. I'm looking for $60 + sh for the one Extremis (8ohm version). They are no longer produced (Adire went out of business) and were originally $99 a piece. I have a pair of Dayton RS52 2" dome midrange drivers. I bought these at Parts Express for a 3-way setup in my car but decided to step to Vifa's TG9 3.5" woofer instead as a better fit for my application. This is a very well regarded midrange, plenty of reviews/test info on them, useful from about 600Hz on up. These are new-in-box, and I am simply looking to get back what I paid for them, $60 + sh for the pair. I have a Phoenix Gold Xenon X400.1 amp as well. It does 400w x 1 at 1-4 ohms, has steep 24dB/oct (rare) crossover filters, subsonic filter. The amp is cosmetically and functionally as good as new. It includes the original packaging, literature, and birth sheet. Nothing is missing or broken. I want $120 + sh for it. Hmm, I think that's it. If I have more, I'l add on. I'm always welcome to pick-up or a local meet if you live in or around souther Minnesota. I know many of these items are on the larger side, and shipping can be upwards of $35-$45, so pick-up is good.
Single. A couple pics I just suggest modeling up the sub you run in these size boxes to make sure the sub is happy in this size and in the case of the ported box, tune as well. The second one shows the gray felt I have. I can carpet up the 1.5 cu.ft. sealed box if you want. A little build up of the ported box. http://www.diymobileaudio.com/forum/showthread.php?t=18244
