Throw out barring
Discussion in 'Modifications And Maintenance' started by 02blubru, Dec 28, 2007.
  1. 02blubru
    Norwood Young America
    Throw out bearing
    What are symptoms of that failing on an 02 wrx sedan. with a clutch that has 25k on it
  2. Paul Revere
    In the land of ice and snow.
  3. wall of tvs
    dream ftw
    difference in noise when clutch is pushed in or out in neutral; typically a squeeling noise, I think
    And wtf is a "barring?" lmao! :p
  4. Bielke55
    Hopkins
    A clicking noise like the one mine is making while the clutch is out.
  5. Paul Revere
    Mine makes a subtle squeak when I let out the clutch, if you wanna hear loud sit in Scuba's car.
  6. idget
    falcon heights
    squeeling+clicking = chirping noise to me
  7. 02blubru
    Thanks guys
    would the ticking be at certain rpms while driving?
  8. curly2k3
    Silent Hill, Jackass
    btw, that would be a throw out BEARING. lol
  9. 02blubru
    i get it, I spelled the word wrong. my bad.
    okay, so my car started to make some noise in 5th, it kind whines as I enter 5th gear and whines while I drive in 5th. if I move the shifter lever while in gear it makes the whine louder.
    beilke, or 3rik, get driftin or ben's opinion please.
  10. Bielke55
    Hopkins
    Hmmm that could be your syncro too...
    EDIT: Or possibly a bearing for the final drive.
  11. curly2k3
    thats what i said, syncros, throw out, or possibly a problem in the diff or a piece of gear or something at the most extreme spectrum
  12. 02blubru
    all the other gears shift smooth as butter. even down into 1st. I am running mobile 1 and it is an 04 wrx tranny
  13. Impreziv
    Impreziv Well-Known Member
    Hopkins
    if its just isolated to fifth gear then i don't think it would be the throw out bearing. didn't you just put this trans in?? The throw out bearing noise would most likely not be dependent upon which gear you are in.
  14. wall of tvs
    dream ftw
    Sounds like a gear issue to me. :(
  15. Bielke55
    Hopkins
    Ben says possible Tail housing bearing
  16. 02blubru
    thanks brian, also are both of these in the tranny?
    I am so happy this started before I sold it to a club member, I would have felt bad.
    it sucks it is only 2 weeks to fix it before the ice races.
    What do I need to fix this? a tranny shop?
  17. curly2k3
    if its something internal it would need a tranny shop, gotta take it apart
  18. Bielke55
    Hopkins
    One of the older techs says you can get at 5th gear with out opening the trans... Just take of the rear transfer... as for anything else i have no idea.
  19. 02blubru
    suckage.
    how drivable is it?
  20. Bielke55
    Hopkins
    If it is just 5th you should be able to drive on it for a quite a while.
  21. curly2k3
    unless he fromrollz a lot
  22. 02blubru
    ^^me and the tractorz up here do it all the time.... *******
  23. curly2k3
    i race john deers fromrollz, i loose.
  24. 02blubru
    bielke, how much to fix it through the shop if it is one of the listed problems. Just trying to get a ball park idea of how much this is going to cost me
  25. 02blubru
    fixed my car.
    took it to DL subaru and had them listen to it and well, guess what happend...
    Not a think, not a cock sucking tit shanking thing... damn cars.
    It has been running great since then.
  26. piddster
    Boostonia
    thats how it goes. Cars never make a bad sound when you want them to.
  27. TSTRBOY2004
    unlike girlfriends etc
  28. AWDimprezaL
    Monticello.
    my guess is that it was ice/snow, and now its thawwed out and fine
  29. 02blubru
    I have a few facts that eliminate that.
    1. drove from perham to buffalo and it started.
    2. did it all the way back from buffalo.
    3. put it in a heated garage for over 24 hours, the floor was even dry. Still made the noise.
    So that eliminates that. Trust me I was hoping to hell it was ice. I will be changing the fluid tomorrow.
    Either mobile 1 or uncle scotty's cocktail. What do you guys think?
  30. TSTRBOY2004
    DINO oil.....
  31. 02blubru
    DINO???
