Throw-out bearing?
Discussion in 'Modifications And Maintenance' started by Dupes, Oct 10, 2007.
  1. Dupes
    Dupes Active Member
    So recently my car has been making wierd metal scraching noises whenever I've got the car in neutral and let the clutch off. If I apply a little bit of pressure on the clutch pledal the noise goes away. My feeling is that it's the throw-out bearing but I'm not sure. I had the clutch replaced less then a year ago with subaru and was wondering if these types of things have a warrenty? Also if this thing goes bad for real, what would the consequences be? Any advice or help trying to figure out what this noise could be would be awsome.
    Chris
  2. Nuke
    year/model
  3. FuJi K
    sounds to be the problem!
  4. Dupes
    Dupes Active Member
    It's a 94 imprezaL FWD. If it's the bearing going bad that's not good huh? I'd have no idea where to start to replace it. Eric or Brian, you guys know if there's a warrenty that goes along with a clutch replacement from less then a year ago?
  5. AWDimprezaL
    i would call and ask.
  6. M155L3R
    M155L3R Well-Known Member
    Subaru one year from date of install, unlimited miles, and depending on condition and or outside influences.
