Time to blow my motor aka BOOST......
Discussion in 'Modifications And Maintenance' started by LVT, Apr 25, 2007.
  1. LVT
    LVT Well-Known Member
    So with the vast amount of swaps and turbos being done, i have decided to experiment with mine and possibly blow my motor(main goal).
    as of now I am currently collecting parts so this will be my little thread on my project.
    A few questions to most gurus out there. I need fuel! fuel pump is cover but what injectors can be used for my 2000 SOHC motor? If possible are there any other compatable fuel rails such as the wrx? If anyone has a set of wrx/sti fuel rails laying around that i could use to test fit or can guarentee it'll fit, it'll be greatly appreciated.
    IIRC the wrx and sti use the same type of injectors as my RS, someone correct me on that? so with the injectors properly seated in the fuel rails, plugging them up shouldn't be an issue.
    or if possible if you read this RUSS, can you modify my stock injectors like the wrx ones?
    the goal is to throw as much boost as i can to my motor. Im shooting for 10lbs boost.
    why do i want to blow my motor? I'm too lazy to work on my car if it isnt' blown....it'll motivate me to put in low Compression pistons or get a ej257.
    THINGS i need, if you have PM me:
    - WRX/STi fuel rails with or without injectors but prefer with injectors(test fit)
    - any bellmouth downpipe, preferbly invidia v3+
    - turbo headers
    - up pipes
    - turbo crossmember
    - engine management, pp6/link+ and the likes
    - boost guage, EGT, wideband o2s
    i'll think of more as i go or give me a suggestion if you think i need something else i'm missing.
  2. AWDimprezaL
    Good boy, im looking to blow mine up too...im "a big dog now" with my td04
  3. Yang
    Yang Well-Known Member
    Why dont you just rebuild it and stop being lazy. I bet you your car is gonna be down for like 6 months before you do anything then you're gonna complain and sell the shell and go buy what you always wanted...Mazda Miata...
  4. LVT
    maybe i will buy a miata as a beater while my car is down :laugh:
    this project will be finished!
  5. Yang
    I got some parts if you want... my v6 tbe and got some headers. the v6 would be perfect for that jdm td04...
    And No, you're not going to finish this project
    ***I'm doubting you so you can prove me wrong and start wrenching before I get boost ;)***
  6. LVT
    your tbe is too small..... :p
    btw, let me test fit the fuel rails and injectors off your leggy turbo.
  7. Yang
    not yet.... the legacy hasnt begun its part out process... I got some 93 L rails laying around if you wanna give a shot at those...I was going to modify them for either pinks or sti injectors...
  8. wall of tvs
    I've got a 90 Miata if you want to trade. :p
  9. AWDimprezaL
    dont do it!
  10. LVT
    it's not being used anyways, so why don't i just come over and take it and give it back after im done.
  11. LVT
    if it's turbo'd with a gt28R i'll do it :p
  12. wall of tvs
    lol yeah I wish it was.
    Even my wife makes fun of how dang slow it is.
  13. Bullwinkle
    Ahah... but it corners good, right, right?!
  14. w_o_t_boy
    w_o_t_boy Well-Known Member
    Yah, it didn't looks like he ever really felt the need to use the brakes when I was following Tom driving that Miata.
  15. asiandude
    asiandude Well-Known Member
    i believe the sti yellow drop right in.
  16. illegal2.2
    illegal2.2 Well-Known Member
    my cousin is running wrx injectors with ralltek o rings.
    choung
  17. LVT
    yah, the sti and wrx needs the o ring kits to place it in there, but i also read that it doesnt' really properly seat it so when it sprays it doesnt' equally distribute it so i would like to try fuel rails that are made for it.
  18. BBsRS
    BBsRS Well-Known Member
    You can take the pp6 i bought from martin off my hands for 300. It includes everthing that i got from martin. Let me know........ pm me......I might have other things available too!!! You know what i got....i just told you the other day.
  19. Dynapar
    I still have a custom uppipe which goes from the stock headers to a near stock turbo location. i had nathan make the pipe for me and it is mint shape, heat wrapped an everything. you could use your stock headers then. also any aftermarket DP should bolt up, you may need to persuade your firewall a little to make it fit easier.
  20. AWDimprezaL
    just a heads up, it doesnt actually fit that well...(at least not on my car)
  21. wagonL
    wagonL Well-Known Member
    wow...lue is going to turbo his car??? hmm...i guess he might beat me in a race....but im not worried...cause im not going to be the one whos going to be towing his car...hahah! :p anyways...get it turboed and then you'll be able to keep up with the rest of us...and then we'll all go cruising like when we were NA...wait...im still NA haha....
  22. Dynapar
    it fit perfectly on my car. cleared the tranny, axles, lined up to the TMIC pretty well. if you are interested you can give it a try and see how it fits on your car.
  23. AWDimprezaL
    im thinking it may have somthing to do with my headers, but yeah it rubbed on my axle
  24. Dynapar
    ^ thats right you have borlas.
    i was actually pretty surprised at how well it fit, cuase i was running at stock hieght when i first did it, then i lowered it ~2" on the perchs when it warmed up, and i still did not rub on the axle.
  25. LVT
    borlas bolt up to the stock parts though but im getting a turbo member so i won't be needed a custom one.
