So I started fiddling with the tune on my 02 wagon, but right off the bat I ran in to an issue. Back story, car is an 02 Wrx wagon with 05 STI swap everything is STI save the heads (2.0), and the intake. Has up pipe downpipe STI mid pipe and custom axle back. Has 3 port GrimmSpeed style intercooler, and an unknown turbo. The clueless previous owner told me 1 step bigger then 05 STI. The car has a few driveability quirks. It likes to stall coming to stops with the AC on, or if both cooling fans are running. The AC did not work when I got it. The idle really does not bump up when turned on. On ECU flash normal idle is 750 with no bump for high electrical load and only 800 for AC on. I changed the high load to 900 and the fans aren't wreaking havoc any more, but it won't allow me to change the AC idle up number. Wtf? I need a full tune and Nuke I will be having you do it once I get some of the little issues sorted out. Any help or insight would be greatly appreciated.
