Tire Storage
Discussion in 'General Subaru Discussion' started by LawnMaster, Apr 30, 2012.
  1. LawnMaster
    LawnMaster Well-Known Member
    Is there any chance that storing a bunch (16) tires in my basement is dangerous? I got to be thinking maybe its really not a good idea. Its a 20' x 30' room and the furnace and hot water heater are on the opposite side of the same room. Should I have any concerns?
  2. Musashi
    I have a rack made sitting on the side in my garage for my street and winter tires. Then all my R comps are stacked in the basement right outside my furnace and water boiler room.
    I wouldn't be as concerned about them causing a fire as much as if I had to get in there should there be a fire. If they're expensive tires put them in large garbage bags and only stack four high. You don't the tires drying out from the expanding and contracting of air.
    Good luck.
    qstarin likes this.
  3. LawnMaster
    Thanks - I appreciate the feedback and the advice.
    Musashi likes this.
  4. Musashi
    You are very welcome. Thanks for the question.
