Tire wear.
Discussion in 'General Subaru Discussion' started by Pecks, Nov 28, 2015.
  1. Pecks
    Pecks Active Member
    So I swapped out my summer tires for my winter tires today and noticed my tires wore out on the inside a lot more then the outside. The fronts are worse then the rears. Any suggestions you guys have would be welcome.
  2. Shabbaru
    Shabbaru Active Member
  3. JasonoJordan
    Online
    Rotate your tires front to back next summer and get your alignment checked
  4. MNGman
    MNGman Well-Known Member
  5. TMF
    Or too much negative camber. Do you have any suspension mods?
    Regardless, you need an alignment. Jeff the alignment guy is the go-to guy and his prices are very reasonable. Email is the best way to get ahold of him.
  6. Shabbaru
    You'd need a ton of negative camber to cause wear that unevenly. I have -4.7 rear and my tires still wear near-perfectly even. Toe kills tires
  7. Pecks
    Pecks Active Member
    I've only had the car about a year and a half and the only thing I've done is buy my second set of rims. Which are the ones with those tires on them. They are the tires that where on my stock rims when I bought it. When I had them out in the rims they didn't look like the tire wear was uneven. Thanks for the input guys I will be getting my alignment checked this week.
