tires
Discussion in 'General Subaru Discussion' started by NMDAYTIME, Nov 16, 2008.
  1. NMDAYTIME
    NMDAYTIME Well-Known Member
    this might be up here already, and yes i know its "winter" but what is the widest you can go on the stis for tread. i was thinking about going with a 255/40 series but can you go wider without a rubbing issue. stock suspension, 04 by the way
  2. Paul Revere
    In the land of ice and snow.
  3. Shibbs
    aka - roll and pull the rears and they may fit if you have a wide enough rim.
  4. mosc
    mosc New Member
    Obviously your wheel offset is going to play a huge part in how it fits. 255 is really pushing it. Also, that guy's running stiffer springs/struts which is going to help keep the tire from rubbing the strut.
    It's hard to say yes/no or what is needed without really looking at the suspension and the offset of the rim as well. Even the specific tire make can be slightly wider/narrower or roll off less/more.
  5. NMDAYTIME
    thanks again guys
