Tools, Tools, and MORE Tools!
Discussion in 'FS: Everything else' started by Shancaldazar, Oct 5, 2013.
  1. Shancaldazar
    Shipping not included. Shoot me a PM if you want to discuss price :). I am located in Northfield, MN currently for school. I occasionally am up in Plymouth if you want to meet up!
    Gearwrench 3 piece 1/2 Drive socket extension set. Contains a 5", 10", 15" extensions for your 1/2 drive ratchet! Knurled so you can easily spin the extension on low torque bolts yourself too. High quality chrome, high strength, and lifetime guarantee through Gearwrench! The 5" has been used but could pass for new. The rest have not been used and just sat in my toolbox for a few months. $20
    Gearwrench 4 piece 3/8 drive socket extensions! Contains a 1.5", 3", 6", 12" extensions. Knurled on the shaft for easy gripping and spinning. High quality chrome, high strength, and lifetime guarantee through Gearwrench. All have been used and are in great condition. $15
    Gearwrench 5 piece 1/4 drive socket extension set! Contains a 2", 3", 4", 6" and 14" extensions. Knurled on the shaft for easy gripping and spinning. High quality chrome, high strength, and lifetime guarantee through Gearwrench. All have been used and are in great condition. $20
    Pittsburgh (Harbor Freight) 3/8 drive 24" extension. Super long, good chrome, hasn't been used. When you need it, nothing else will do! $10
    Northern Industrial (Northern Tools) 8 piece adapters and universals set. Contains a 1/4, 3/8, and 1/2 universal joint, a 1/4 to 3/8, 3/8 to 1/4, 3/8 to 1/2, 1/2 to 3/8 and 1/2 to 3/4 adapter! Never been used before, just sat in the tool box. Nice and chrome, and very sturdy. $15
    3 pairs of brand new Knipex 8" combination pliers (#03-200). Made in Germany these are some of the best pliers you will ever use! Lifetime warranty and 60 HRC hardness cutters. Can cut up to 16MM of copper cable with insulation, which means it will do more than you need it to for auto work! Very, very, very nice pliers. $20 each.
    Craftsman 12 Piece SAE wrench set (6 point box end). Contains 7/8, 13/16, 3/4, 11/16, 5/8, 9/16, 1/2, 7/16, 3/8, 11/32, 5/16, 1/4 wrenches. The box ends are 6 points for better grip on a fastener. Craftsman wrenches are a great bargain and of course have a lifetime warranty! These also have corner driver technology to prevent rounding off nuts and bolts! Get them now before you need to help your neighbor work on his domestic car (also nice to have around if you round a metric bolt, and use the slightly smaller SAE equivalent)! Never been used before! $25 for all 12 wrenches!
    Craftsman 12 Piece SAE wrench set (12 point box end). Contains 7/8, 13/16, 3/4, 11/16, 5/8, 9/16, 1/2, 7/16, 3/8, 11/32, 5/16, 1/4 wrenches. A 12 point box end allows twice the positions of a 6 point for improved access in tight areas! Lifetime warranty, Craftsman quality and corner drive technology for less rounded nuts and bolts! Never been used before! $25
    Gearwrench 10 Piece ratcheting SAE wrench set. Contains a 13/16, 3/4, 11/16, 5/8, 9/16, 1/2, 7/16, 3/8, 5/16, 1/4. Great condition, never been used. Lifetime warranty through Gearwrench. Uses Surface drive Plus technology for less rounded nuts and bolts! All ratchet smoothly and work great! $50
    Bostitch 6 piece Punch set. Regular length punches that have been used quite a bit. Contains a 5/16 (8MM), 1/4 (6MM), 3/16 (5MM), 5/32 (4MM), 1/8 (3MM), and 1/16 (1.5MM). The tips have some surface rust, and the smallest punch got bent, and I bent it back (you can't tell it was bent). They have a 100 year warranty (sold at lowes). They are dipped in rubber so only the punch part itself is exposed. Nice when it is cold outside. $5
    Harbor Freight Pittsburgh 5 piece Long Pin Punch Set. Contains 1/8, 3/16, 1/4, 5/16, and 3/8 punches. Handles are knurled for improved grip and are extra long, making it easier to punch out pins in recessed spots (cough, shifter linkage, cough). These have never been used however! $5
    Evercraft (napa) CV boot clamp pliers. This a tool that helps install those difficult CV boot clamps (crush bands only, not dual bands). Rubber dipped handles for comfort, and only used twice for installing CV boots. Lifetime warranty at Napa Auto Parts. $5
    Gearwrench T70 1/2 drive torx bit. The socket is made from Chrome Vanadium steel, and the bit is made from high strength S2 steel (same type professional brands use). Lifetime warranty and a quality piece! $5
    A bunch of 3/8 drive, 36 tooth ratchets are still up from grabs! All are unused, come with a 5/8 socket, and are strong and durable (I have two I've abused to no end and they still work!). Great ratchets to bring to a junkyard or keep in your car! 5 for $5
  2. Shancaldazar
    1 Knipex pliers has been sold (2 left), and bostitch punches are sold.
  3. phi11
    I'll buy a set of 5 for $5 ratchets!
    tonyM likes this.
  4. MNSnoDrifter
    I'll take the T70
  5. Shancaldazar
    I'm up in northfield so not sure if you want to meet or ship it.
  6. MNSnoDrifter
    well if I go on that cruise this weekend maybe we can meet in Cannon Falls?
  7. Shancaldazar
    Sure. Let me know what happens.
  8. Shancaldazar
    THIS IS WHAT I HAVE!!
    FIVE LEFT brand new Channellock 911 Cable cutting pliers. Useful for any copper or aluminum wires, cables, etc (not for steel). They use Channellock's patented Knife and Anvil style cutters for more precise and easier cuts that are laser treated for long life! Also has Blue comfort grips on it! Channellocks are fantastic pliers Made in the USA with a lifetime warranty and some of the best you can buy out there! 9 inches long, I may remove packaging in order to ship it cheaply. $20 each
    ONE pairs of brand new Knipex 8" combination pliers (#03-200). Made in Germany these are some of the best pliers you will ever use! Lifetime warranty and 60 HRC hardness cutters. Can cut up to 16MM of copper cable with insulation, which means it will do more than you need it to for auto work! Very, very, very nice pliers. $20 each. Packaging will have to be removed for shipping.
    Craftsman "L" shaped metric hex key set (20 piece!). Lifetime warranty, Made in the USA, and strong little pieces (no weak Chinese steel!). Craftsman tools, enough said! Larger set than you can find anywhere else for just metric "L" keys. Only 1 of these has been used, the grime is simply from the oil coating these to prevent rust. $10
    Craftsman "L" shaped SAE hex key set (20 piece!). Lifetime warranty, Made in the USA, and strong little pieces (no weak Chinese steel!). Craftsman tools, enough said! Larger set than you can find anywhere else for just SAE "L" keys. None of these have ever been used, the grime is just from the oil coating them to prevent rust. $10
    A bunch of 3/8 drive, 36 tooth ratchets are still up from grabs! All are unused, come with a 5/8 socket, and are strong and durable (I have two I've abused to no end and they still work!). Great ratchets to bring to a junkyard or keep in your car! 5 for $5 9 left.
