tranny bolt size ??
Discussion in 'Modifications And Maintenance' started by Justin, Dec 12, 2007.
  1. Justin
    Justin Well-Known Member
    do any of you know what year subaru started putting the t70 torx in the tranny drail plug? i know for sure an 05 has it but i'm not sure about the 04s.
    thanks
  2. EtchyLives
    EtchyLives Well-Known Member
    I think the 03's were the transition year. Don't quote me on that, though.
    I know that 02's are the 21mm bolt.
  3. Justin
    so you think for sure the 04s and maybe even the 03?
  4. AWDimprezaL
    For sure 04s too
  5. AspitFire
    yes for sure 04, mine did
  6. Justin
    3rik..any way you can look up to see if the 03's have it?
  7. AWDimprezaL
    Well it wont be for sure, my catalog is in JDM, so 02 over there is 03 over here, lemme try
  8. AWDimprezaL
    hmm, looks like 03 is still up in the air
  9. Justin
    ok...
  10. AWDimprezaL
    OKAY brian just said his is a normal non hex, his car is an 03
  11. EtchyLives
    I'll say it again: I think 03 was the transition year. Some have the Torx, some have the 21mm.
  12. Justin
    ok great thanks guys!
  13. subytek
    subytek Well-Known Member
    This man is correct. The leggys and foresters changed in 03, than some wrx's in 04, and all cars in 05.
  14. Chin
    Chin Well-Known Member
    My '04 STi doesn't have the Torx.
  15. GrimmSpeed
    GrimmSpeed Vendor
    anyone know if/when the sti's had the torx?
  16. subytek
    No, they do not. One 21mm, and one 14mm. You should drain both.
  17. GrimmSpeed
    GrimmSpeed Vendor
    thanks ben. 'twas my assumption.
