Tranny fluid Suggestion
Discussion in 'Modifications And Maintenance' started by Yang, Jul 29, 2004.
  1. Yang
    Yang Well-Known Member
    I plan on changing it soon. What should I go with and where can i get it?
  2. Musashi
    Yang,
    I use Redline in mine, you can get it almost anywhere in town, but if you dont know, I can direct you to my friend who has shop that services F1 cars.
    C
  3. Yang
    Is red line safe with my tranny ? I heard they are kinda bad in the long run. Is synthetic for daily driving or more like racing, autX? I haven't really done any hard-core stuff yet*. I dont want to go with synthetic unless its safe, well for me at least;)
  4. WRX1
    Online
    I can get ya some amsoil that is syncho friend for my cost. It comes out to $6 per quart. Let me know.
  5. Musashi
    Yang,
    What do u consider SAFE, I'm not as hardcore as you, if you know what I mean, considering your most recent experience. Your a funny guy.
    Ok, on a serious note, Redline is safe, along with many other synthetic fluids out there, it really does not matter what you go with, whats important is the grade of what ever brand you go with, just make sure you check with your owners manuel so you know what weight to get and how much to use.
    You many want to consider doing your own research and find out what works best for what your needs are.
    Enjoy,
    C
  6. Yang
    Thanks Chong :I,
    Russ: Let me check my OM and get back to you
  7. Musashi
    Russ alwayz got everyones back especially when it comes to Amoils.
    Thanks, Russ.
    C
  8. RallyNavvie
    RallyNavvie Well-Known Member
    I personally find sawdust to be an excellent replacement for transmission fluid :D
  9. Chux
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by RallyNavvie
    ROFLMAO!!!!! :p
  10. slavboy1
    slavboy1 New Member
    Hey how often should you change your tranny/differential fluid? This is for an 05 STi tranny. Thanks
  11. FuJi K
    I need syncromesh!
  12. TSTRBOY2004
    I used Amsoil in mine... made is a heck of a lot quieter and smoother... 75w90 I believe...
    I would recommend it... a buggy ran the same in his 04 Sti
  13. wall of tvs
    I'm not sure if my problem was related to anything, but I had to have my 1st and 2nd gear synchros replaced about a month after switching to Redline 75w-90ns gear fluid a while back. This was when the car was completely stock, and I don't abuse the tranny at all.
  14. AWDimprezaL
    if your wanting to smooth out your tranny...synthetic isnt the way to go, if you want to stop grinds, GM syncromesh is teh hotness, works for me for the last 30K miles, no grinds!
  15. TSTRBOY2004
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by AWDimprezaL
    sp you are saying synth wont smooth out the tranny... hmmm funny that.. cause I put it in mine with 30000m and I felt like I was deaf afterwards.. it WAS xmoother and DEFINITELY quieter... but hey if it doesnt work it doesnt work.. maybe I imagined it...ha ha
  16. AWDimprezaL
    sythetic does alot better job lubing things, but it does it too well, mostly if your tranny is already getting a little worn, in other words, if your having grinds right now, synthetic WONT help, it will make it worse
  17. Chin
    Chin Well-Known Member
    I have put ~50k on Redline in the RS (some know that it's only use is abuse). I would have to say that the nay-sayers should have there tranny checked before putting in fluid...that way you know that your tranny is going to go anyway, and you don't blame the fluid. (not directed at anyone here) }:)
    Oh, and I have been using Redline in the STi for ~15k with no issues.
    My vocal $0.02
  18. AWDimprezaL
    i say nay from experience;), all cars are different, pete, chime in and voice your love for the syncromesh also
  19. Chin
    This is only partially true...look at the available oils from Redline, there are different weights and blends. The latest "super-mix" is 3 parts MT-90 and 1 part shockproof lightweight.
    Also, what is this "experience" that you are speaking of? Did you know the tranny was perfect before you put the Redline in? Is there evidence that the gear oil caused the failure? Like I posted previously, people like to "blindly" blame the oil rather than find the real cause... maybe, you can prove me wrong in this case (and I switch my fluid ASAP). I have seen a lot of reasons for trannies failing, but I haveyet to see the evidence that a particular oil caused failure... With so many tranny failures on the WRX, it appears pretty logical that there is an outside influence independent of the oil. One thread I read this weekend noted that many of the rebuilds the particular poster had performed had stock fluid and it was old, leaving sludge behind. While I do not claim to be any sort of expert, go through and compile all of the reports of tranny failure and look for how many are even running Redline...once again, I believe there is a different root cause and Redline takes some flak for that.
    Well, looks like I am up to ~$9.00 worth of opinions...time for a new bottle of Redline. ;)
  20. AWDimprezaL
    my experience was i had grinds in 1-3 with regular 75w gear old, then i switched to mobile synthetic, i had grinds in EVERY gear, regardless of temp, or speed, and im not ragging on redline, im ragging on synthetic in general, i switched to syncromesh as a last resort before tranny rebuild, no grinds whatsoever in any gear at any time, i could put it into first at 40 if i wanted to, no grinds. Im sure if you used redline since your car was new, or any synthetic for that matter you probably wouldnt be having any problems right now
  21. TSTRBOY2004
    ahh... now we are tracking... so we are on the same boat.... yep I would agree no amount of any good lubes would replace crunched metal.. ha ha ha
  22. WRX1
    Online
    but you also have to remember that certain lubes are not syncro friendly. Amsoil make 4 different gear lubes now, and 2 of them are not synco friendly (too slippery), and they just release a syncomesh formula. I know erdline and royal purple also have synco/non-syncro formulas. So you just can't say that all synth fluids are no good, you have to specify what fluid you are refuring too.
  23. 6MTizzle
    6MTizzle 2SLO
    Synchromesh made 4th gear happy :D
  24. RexN
    RexN Well-Known Member
    Can anyone comment on this? I am due for an oil and differential fluid change soon. Instant Valvoline is charging about $50 for full synthetic oil change and $50 for rear diff oil change. For $20 more I can get the complete package.
    http://www.redlineoil.com/team_gear.asp
    Appreciate any input :)
  25. Chin
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by RexN
    Well, you are comparing apples to oranges, here... The "package" is for the oil only, while Inst Valvoline is including the labor (and very likely a cheaper synthetic). That aside, a quart of Redline goes for ~$14... for a STi, you need 5 qts, if I remember correctly. That comes to ~$70, plus the quart for the diff...~$85 rounded off. Now the questions are... will you do it yourself? If so, then you have a far better deal than going to Valvoline. The important question regarding the "package" is; do you need all of that? Water Wetter, Fuel cleaner, funnel and a hat will cost you an additional $35 when purchased as a package... I personally have never used Water Wetter (not too hot here, nor do I run really long track sessions of 30+ min) or fuel system cleaner so they would be wasted on me, but you may have different plans...
    Well, if you were able to follow all that, you should be qualified to change it yourself... Go ahead a buy 5 qts of 7w90NS and 1 qt of 75w90 and go for it... or if you are looking for a little better mix, try the combo I listed previously (MT90 and Shockproof). Of course, there is no consensus as to whether or not you should be using Redline so do so at your own risk. (I use it almost exclusively, but I have tried Motul as well and like it too)
