transmission swap
Discussion in 'Modifications And Maintenance' started by 25iguy, Nov 6, 2007.
  1. 25iguy
    25iguy New Member
    is it possible for me to put a 6 speed in a 2.5i
  2. Dynapar
    yes, it is. it is quite an involved process though. It is also not exactly cheap.
  3. AWDimprezaL
    yup, wouldnt be easy at all, you'll need, a rear diff, 6 speed axles, depending on year, you may need hubs, rotors, wheels, clutch, shifter linkage and shifter assy....basicly what we're saying, is its not worth it, at least not into a 2.5i
  4. piddster
    6mt tranny
    6mt shift linkage
    6mt clutch/flywheel
    Auto driveshaft
    6mt tranny mount- just the mount, NOT the crossmember
    3.90 rear end - this can be done fairly cheap.
    You can buy a 3.90 ring and pinion, or go to
    the junkyard and get a 3.90 rear diff from
    something and swap in teh ring and pinion to
    keep your VLSD
    Depending on your car, you might need axle stubs for the front axle shafts. If your 5mt has stubs for your axels, you'll need them. If the stubs are part of the axle, I think you're fine.
    As far as a DCCD controller goes, you can drive without it if you want. I've been going without it, but that straight 65% rear-bias can get interesting at times, especially with an open rear diff. Using the factory controller really isn't an option because it gets several inputs from the ECU, so you'd have to give an STi ECU enough inputs to be happy and supply the DCCD controller with what it needs. PITA, imho. A guy from nasioc makes controllers, which seem pretty decent. I've got one on the way. http://www.dccdpro.com/
