tree sap
Discussion in 'Modifications And Maintenance' started by shoeboy81, Aug 8, 2007.
  1. shoeboy81
    shoeboy81 New Member
    Hey guys and gals,
    I have a little problem. I cannot get two spots of tree sap i got on my legacy two weeks ago up north fishing. I have tried coke classic, which my mechanic told me to use, and it did not work. I know of two other "things" to use but they may hurt the paint. Any help would really be appreciated. Thank you all and have a great day.
    Shoeboy81
  2. 1_sic_rex
    1_sic_rex Well-Known Member
    Get a bounce sheet and get it wet.... not too wet. That might work.
  3. Yang
    Yang Well-Known Member
    wd-40 ... it works. Sometimes it works too good LOL
  4. deegee
    deegee Well-Known Member
    Claybar won't take it off?
  5. Dream
    Bug and tar remover, can get it at most auto stores.
  6. Deride
    Denatured alcohol and a polishing cloth.
  7. AWDimprezaL
    let some glass cleaner soak on it. thats what ive always used as a detailer. it may take a few tries, but its the safest
  8. tangledupinblu
    3m all purpose adhesive remover. Safe on paint. Check your local Napa.
  9. COBBsoobyStage1
    COBBsoobyStage1 New Member
    gasoline
  10. blackozone
    Brake Fluid. Like a charm...:yumyum: :wiggle:
    (P.S. By the way, don't use brake fluid.)
  11. curly2k3
    two weeks, that has already done the damage on the paint, but SeaFoam Bug remover should still be able to get it off, that or 3m adhesive remover like Josh said works too
  12. TSTRBOY2004
    monkey piss.....
  13. angusracer
    angusracer Well-Known Member
    and the most effective yet usaid... dishsoap + WATER mxed together to create a concostion that has worked for ages
  14. Deride
    Seriously, denatured alcohol..... sap comes off like a prom dress when you add some denatured alcohol to the mix.
  15. tux121
    tux121 Well-Known Member
    This black guy sold me some good cleaning stuff. It's called GREEN APPLE ADVANTAGE and it cleans rims SO MUCH BETTER THEN Brake Dust Cleaner! Comes off the second you use it and I'm pretty sure Tree Sap aint a problem. It's water base and won't hurt your paint. No smears either.
  16. blackozone
    What difference does it make if it came from a black guy or white guy? You trying to say that white guys don't know how to clean?
