Tuned yesterday at DB - Dyno Sheets
Discussion in 'Photo & Video Gallery' started by WagonsRock, Apr 11, 2007.
  1. WagonsRock
    WagonsRock Well-Known Member
    I finally got my car tuned up a bit at DB Performance yesterday. There is still a little bit of work that needs to be done to get the tune right, but the car is well on its way. You can see my list of mods in the member's cars gallery.
    So what do you guys think of the dyno plots? Anything look weird to you? The overall horsepower reads a little low at DB I heard, not that a number is what it is all about. Correct me if I am wrong, but I think I remember shane saying that a stock STI on their dyno was around 210 whp and Fong's modded Forester put out about 240..something at the dyno day last week.
  2. Dream
    You might want to list your mods.
  3. AWDimprezaL
    ^^ word to your mother. stage 2?
  4. WagonsRock
    I was too lazy...
    DB performance 92 oct map
    16g EVO III turbo
    Ebay TMIC
    Modded WRX injectors (680cc)
    Walbro 255 fuel pump
    Samco turbo inlet hose
    Samco y-pipe
    GM EBCS
    Apexi GT Catback
    Megan Racing DP
    Gutted UP
    K&N Typhoon CAI
    Cusco 22mm adj rear sway
    Perrin rear endlinks
    Tein S springs
    18" MB Weapon Wheels
    Hawk HPS pads
  5. Scuba Steve
    Looks good to me. I thought a stock sti should put out 225 whp on the db dyno, I might be wrong.
  6. Dream
    hmmm, I would think you would be closer to 300 with those mods. Maybe you had some bad gas :ugh:
  7. shineynitelite
    lol @ dream
  8. WagonsRock
    Like i sad, correct me if I am wrong. I have actually never had the chance to ride in an STI so I really don't know how to base the new feel.
  9. Sogonerg
    Sogonerg Anteater
    closer to 300whp would have been my guess too...what was your max PSI?
  10. Justin
    Justin Well-Known Member
    read the sheet fooo
    18.5 is max
  11. wall of tvs
    Man, you should've picked up a GM bcs for your install/tune. I would imagine that if boost was held at 17-18 @ redline, you'd be much closer to 300whp.
  12. Scuba Steve
    I honestly thought 260-280 whp was the range for a 16g on that type of dyno....I would be glad to be wrong:biggrin:
  13. badbennyb
    just FYI my stock 05 STi made 226hp/230tq at DB.
  14. WagonsRock
    The first picture has it in there.
    I was thinking that I would run higher boost also, but Shane thought that 18-18.5 was about right for a dependable setup. My newbie thought was around 19-20psi.
    Like I sad earlier, I need to talk to Shane about going back in. In the time I have driven it since last night, the turbo pressure has pulsed pretty bad quite a few times on the top end of my boost. Basically, it will snap up to about .13MPa and then dip back down to about .11MPa about twice before it settles back up at .13MPa at WOT. Anybody else experience this ever?
  15. Sogonerg
    Sogonerg Anteater
    missed the first graph
  16. WagonsRock
    I do have one in there....
  17. Sogonerg
    Sogonerg Anteater
    Yup...but mine was worst...It looked like a heart beat...Spike up to 18-19psi and dropped about 4-5psi instantly, plus I was running way too rich...Got mine tuned to get rid of it, so Shane should be able to get that out there. My vf34 reliable @ 21psi after the tune...I would assume 20psi proper tune would be good for a 16g setup
  18. wall of tvs
    19-20 is what I'd want to run on that turbo and then taper it down to 17-18 by redline.
    Where are you seeing the boost spike? Right at the onset of boost or more like at 5500rpms or what? Also, in what gear is this happening?
  19. wall of tvs
    heh, I can't read. lol.
  20. Iroc-Z
    Iroc-Z Well-Known Member
    Woot your 16G makes 1 hp less then my vf39
  21. wall of tvs
    heh, it should be making much more.....
    An evoIII 16g is almost the size of an 18g in terms of CFMs.
  22. Iroc-Z
    I believe that I am just stating the obvious. Same dyno and same tunner.
  23. wall of tvs
    :p
    and so am I.
    :p
  24. WagonsRock
    You run 21 psi on pump gas with your vf34?! That seems real high from what I have read. What am I missing?
    Wall of tvs....
    The turbo spools like it should right up to 18-19, but right when it gets there, it bounces back down. Happens with different severity in each gear. I've only driven like 70 miles with the tune now, so I don't know all the peculiarities yet.
    I don't want to make it sound like I am bad-mouthing what Shane at DB did. He's a good guy and seems to know what is going on. Also, he told me if the turbo did do the surging thing to give him a call, so I think he had his suspicions that it would happen.
  25. wall of tvs
    Sounds like a combo of incorrect wgdc targets and too much turbo dynamics correction.
    From my limited time on the dyno I've noticed that they put much more load on the car than you'll see on the street. Hence, it can be tricky to dial in a boost curve that will work 100% correctly on the street.
  26. kickin_81
    kickin_81 Well-Known Member
    You're about right. My FXT made about 248 WHP and 249 WTQ on the dyno last week on my OTS Cobb AP Stage 2 map. I've since unflashed my ECU from the AP and should now be pumping out 271 WHP as I did last year. :biggrin:
    And congrats on your tune. Going to test what it can do at the Rock this Sunday?
  27. Dynapar
    Number look good to me. sure you might not be squeezing every tiny bt out of the 16g, but compared to my number at DB (113WHP, 143WTQ) your doing just fine :)
  28. WagonsRock
    When I was talking to Shane yesterday he said that we were right on the edge of knocking. If that's true, waht are some ways that I can run higher boost without higher octaine gas?
  29. wall of tvs
    Turn the boost up and the timing down. It's that simple.
    You can be on the verge of knock at 7psi or 27psi. What matters is that the ignition is suited to the given load at a given rpm.
  30. WRX1
    Well, with my limited tuning ability, everything should be shifted to the left 4-500 rpm. What kinda of timing are you running at 4-4500 and up top(6k+)?? If I would have tuned it, 20 in the mid and 18 or so up top, but again as I have been previously told, that I don't know what I am doing.
  31. wall of tvs
    lmao!
    get outta here, n00b! :p
  32. Sogonerg
    Sogonerg Anteater
    I was mapped at 92 oct. and my A/R is perfect after the tune and was boost'in @ 21psi...I asked about it and Doug (topspeed) it was fine usually he mentioned VF34 can be effient around 18.5-20psi depending on what other mods are on the vehicle. But 21psi for mine is pretty much maxed out and it still show that it is effient throughout the band...Plus usually your tq level is less than HP...we had matched up well with the HP to TQ ratio it was like 252whp to 250wtq in the DD dyno. I know peeps get around 230-240 tops from what I've seen on a VF34 I think it was due to my Gt-Spec Header/up-pipe combo very nice piece and upgrade.
  33. vangthao02
    vangthao02 New Member
    what did you used to controll your fuel system??
  34. AWDimprezaL
    probably an accessport, maybe openecu....
  35. webcrawlr
    webcrawlr Well-Known Member
    I heard it was a Mr. Fusion and it wasn't bad gas it was bad food.
  36. AWDimprezaL
    kudos for the back to the future quote ;)
  37. WagonsRock
    I am running an accesport.
    I hate to go back in and sit on the dyno for another 2 hours. That stuff is expensive. 150/hr
  38. Sogonerg
    Sogonerg Anteater
    Shane should give u some sort of credit...and not charge the full price since he was the guy that tuned your car and you didn't like it.
  39. Dizmal
    Dizmal Well-Known Member
    Don't these places take it for a road drive after performing the tune? As stated, the dyno is hardly real world driving. You would think so, but what do I know?
  40. Iroc-Z
    Shane did alot of road tunning on my car
  41. WagonsRock
    I talked to Shane today and I am going back on Tuesday to get some more work done. As some of you suggested, he said we might just have to go out and do some road tuning with it. He also said that my car, for some reason, was exceptionally hard to get the boost right. I guess I just have a stuborn car that doesn't like it's brain messed with.
    Any of you have any words of wisdom that I can pass on to Shane on Tuesday?
  42. Dynapar
    and you break trannys :)
    i would inquire about some extra tuning if you arnt satisfied, perhaps at a discoun rate
  43. WRX1
    I don't break the tranny's, the owner of the car breaks the trannys. I just get them the power needed to break the tranny. What they do with it after that is their own problem.
