Tuning for ECM
Discussion in 'General Subaru Discussion' started by Matthew Hill, Oct 19, 2015.
Tags:
  1. Matthew Hill
    Matthew Hill New Member
    I have a 2011 Subaru Impreza WRX. I took the stock exhaust off of it and put some cat back on it. Now i need the ECM tuned. I live in Menomonie Wisconsin. Any places you suggest?
  2. tangledupinblu
    You don't need a tune for a catback. Turboback you would tho.
    Good tuners in the TC's would be RS Motors, NF Performance, DB, or Devin at JM Automotive.
  3. Matthew Hill
    The cat is completely gone though messing up my air fuel, based off of what the sensor would say.
  4. tangledupinblu
    Sounds like you did a turbo back. Cat is on the down pipe. So you do need a tune!
  5. Matthew Hill
    Thank you very much. Do you happen to know who is cheapest?
  6. tangledupinblu
    Probably NF or Devin at JMA. RS and DB do dyno tuning, which is usually a fair amount more.
  7. Jake underwood
    Jake underwood Member
    If you think you'll be doing multiple Maps(91 octane, 93 octane, e85 etc.) I'd reccomend getting an accessport. Tangledupinblu named all the reputable tuners around the cities. I'm sure there's a couple in Wisconsin as well. Also
    You might want to hurry up because I've heard of a few shops not doing tunes when the weather temp is below 40 degrees.
