Turbo build part out: gt40r kit, fmic, ej257 halves, built heads, supporting mods
Discussion in 'For Sale : Car Parts' started by idget, May 21, 2009.
  1. idget
    Specific pics available upon request, but post #2 contains pics. Please pm me if you are interested in purchasing any of these items.
    All items are brand new in box unless otherwise noted. They were opened for inspection and pictures only.
    1) Block Halves EJ257 with Subaru OEM Gasket Kit $800 (retails over $1200)
    2) Cusco Hyper-Disk Clutch (single) $650 (retails over $1000)
    3) Hydra Nemesis II for WRX $1200 (retails $1500+)
    4) Hydramist full kit $600 (retails over $750)
    5) GT40R Ultimate Racing Single Scroll .72 hot side for fast spool FULL KIT including tial wastegate, tial bov, Ultimate racing Front mount intercooler, etc
    Similar to this kit:
    http://www.ultimate-racing.com/Products2/WRX-STi_02-07/WRX-STi_02-07_GT40R_TurboKit.shtml
    except with custom A/R
    includes something similar to this fmic kit:
    http://www.ultimate-racing.com/Products2/WRX-STi_02-07/WRX-STi_02-07_FMIC-Kit.shtml
    except no overflow tank but includes tial bov
    $6000
    6) Ultimate 1000cc injectors (WRX - top feed) $300 (retail $450)
    7) FULLY Built WRX Heads *Built By Andrewtech PPG* $2000 (Cost me $2500+) with new internals (springs, valves, retainers, camshaft 262, ported polished intake, cleaned and measured. *Internals are Crower racing* The Cams alone are $750.
    8) JE Piston (stock bore 99mm) This is not the standard one, the side and crowns are double coated to handle high boost and Nitrous $550 (retail $750)
    9) Nitrous Kit $350 still in box (NOS dry kit)
    10) 04-05 Seibon Hood RS style with FULL ventureshield invisible bra (not just the leading edge. The entire hood is covered) $600 (retail $650 + $500 film)
    11) Extreme Dimension Reverse hood scoop. Used, has small chip shown below $300 (retail $550+)
    12) Defi gauges (wrx green, 6 gauges and defi link) -
    3 are brand new in box:
    52 mm water temp
    52mm fuel pressure
    52mm oil temp
    3 are mounted (but never wired in) in a custom fiberglass clock pod that includes a Heads Up display:
    52mm boost
    60mm tach
    52mm oil pressure sold
    1200 for all. Willing to separate too
    13) crower rods 600
    14) oem ej257 crankshaft 275
    15) Driveshaft shop aluminum driveshaft 400
    16) driveshaft shop 500hp rear axles (RA8524 l5) http://www.driveshaftshop.com/pdetail.php?pid=575 1000
    17) PPG front LSD http://www.ppgearbox.com.au/page.asp?parentid=3&parent2id=14&parent3id=31&productid=67 1200
    18) Kartboy/TiC 5mt shift bushings (front, rear, and pivot) 60
    19) compustar p2w900fm-a 220
    21) ppg 5mt shift forks 450
    Yes, these are from the build you are thinking about. Yes, it really sucks that the build wont be finished.
    Please keep posts on topic (questions about parts you are interested in buying, vouching for the seller ;), notifying me that you've pm'd me, etc...).
    thanks for looking!
  2. idget
    11)
  3. fobiawrx
    fobiawrx Fabiola
    are these rays parts?
  4. idget
    These are dusty parts if that answers your question :laugh:
    bump. added pics to post #2
  5. piddster
    Is that a Hyper Single or Hyper Twin?
  6. wrxsti_02
    wrxsti_02 Well-Known Member
    How much does he want for the oem ej257 crankshaft?
  7. idget
    dan, clutch is single.
    275 for the crankshaft.
  8. MrMcMonkey
    MrMcMonkey Well-Known Member
    pm'd on the autometer stuff
  9. tux121
    tux121 Well-Known Member
    Are you willing to part out just the turbo kit and not the intercooler kit?
  10. idget
    Yes. Pm me
  11. dipp
    dipp Well-Known Member
    Pm'd you on the defi 52mm Oil press gauge i needz this.
  12. Dream
  13. idget
    pm's replied.
    bump
  14. idget
    pm's replied.
    bump
  15. idget
    Bump. Going up on nasioc this weekend.
