Turbo inlet?
Discussion in 'Modifications And Maintenance' started by Iroc-Z, Jan 3, 2007.
  1. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    Was looking at turbo inlets for my vf39 swap. I was going to go with a silicone one but I also have heard alot about the aps one. Any opinions?
  2. AspitFire
    MN
    i was reading a thread today that compared the silicone ones and the aps one and basically it said the ID of the silcone ones actually come to a smaller point at the neck then the stock one does. I guess APS is the way to go even though you HAVE to remove the IM.
  3. Justin
    Justin Well-Known Member
    St. Paul, MN
    all silicone ones blow. the aps one is the way to go. i believe there is a knock off aps one out there now too but i forgot what the brand was. imo, just buy the knock off since all it is is just a aluminum tube with some NIPPLES.
  4. WRX1
    Over there
    You also need to remember that with the aps one that you need to remove the tgv sensors and motors. I guess the silicon one is ok, I would go with the avo hose. The house goes all the way from the stock box to the turbo and it BARELY fits under the manifold.
  5. Iroc-Z
    New Germany, MN
    The avo one looks like a nice peice. But for 500 bucks. Thats alittle steep
  6. Dream
    south
    I used the Perrin with my 20G and had no issues....
  7. Steve-o
    Drinking.
    My perrin one seems to work fine too. :dunno:
  8. wall of tvs
    dream ftw
    I had a Perrin one on my old car and I noticed a bit better throttle response with it.
    However, the fitment of it was on the borderline of what I'd consider to be garbage. And I'm pretty sure it wasn't just a random manufacturing flaw since w_o_t_boy's Perrin hose fit just as bad. Between that and the Perrin IC hoses I had, I'll more than likely never buy one of their products again.
  9. LegacyPGT
    LegacyPGT Well-Known Member
    not in a Subaru
    I have installed a few APS inlets on the ej20's and ej25's and the fitment is A+ and you don't have to remove the TGV's
    My vote goes for the APS
  10. Iroc-Z
    New Germany, MN
    You do have to move the fuel pressure regulator dont you?
  11. LegacyPGT
    not in a Subaru
    You only have to move the FPR on the EJ25's, and the kit will come with the stuff to relocate it
  12. Iroc-Z
    New Germany, MN
    Dumb question but is the fuel pressure reg in the same general location or is it in a totally different location?
  13. LegacyPGT
    not in a Subaru
    well on the ej20 it is one the right hand side fuel rail, on the ej25 it is under the factory turbo inlet, by its self.
  14. Iroc-Z
    New Germany, MN
    Good cause I wasnt wild about moving it.
  15. MNAutomatic
    MNAutomatic New Member
    I'm on the westside
    I am having my perrin taken off this week by PHATsuby...if you want it shoot me a PM and I will let you know a price.
