Turbo oil lines
Discussion in 'Modifications And Maintenance' started by Frogy, Nov 23, 2007.
  1. Frogy
    Frogy Well-Known Member
    Has anyone installed any aftermarket turbo oil feed/return lines what are the best options?
    I have done a little searching but I ahve not fond much info.
    frogy
  2. piddster
    I just pieced mine together with -4 teflon and the proper fittings. It cost me $40
  3. Frogy
    which line return or feed, what is -4?
  4. AWDimprezaL
    yes piddster, where did you get the stuff, i am in need of a feed system
  5. Scuba Steve
    If you have a stock turbo or stock like turbo you can do what i did...
    i got mine through Forced performance. the ss line was easy to install. I have it going straight up from the engine, over the heat shield, then down to the turbo. I wrapped the part of the line that goes over the heat shield to protect it from rubbing and heat.
    With the return line I didn't care too much about since the turbo just dumps the oil out the bottom. you can use a rubber hose. I don't think there's a benefit to an ss line.
  6. AWDimprezaL
    ide love to do that steve...but mine will be 100% different, pics perhaps tomorrow, think huge
  7. AWDimprezaL
    shhhhhhhhhhhhhhh alex
  8. Scuba Steve
    the pics were for frogy....
    What do you have cookin? spill it
  9. Dynapar
    hard line is the way to go. doesn't wear out like braided stuff, which has a rubber core.
  10. piddster
    Mine doesn't have a rubber core, its teflon, just like brake lines and what not. I didn't really have a choice with a rotated mount turbo.
    I was installing an exhaust on a friends '07 STi and noticed it had braid brake lines from the factory. They had a clear plastic sheath over the line though, since dirt is what leads to a braided line's failure over time.
    I got all the stuff at Northern Engine Supply in Duluth. Its all Eaton fittings. Eaton is the parent company to Aeroquip, which is a subsidary of Honeywell, IIRC. I think MAS sells the same steel fittings. Unless you need to save the 4oz, steel is the way to go. I also got a -8 45 degree adapter for $6.50 at Northern, compared to around $30 for an aluminum counterpart. The steel fittings are also more compact.
    That was for my feed. My return is a bastardized compilation of 5/8", an adapter, and 1/2" hydralic hose. I learned my lesson about using heater hose, which doesn't like oil.
    -4 refers to a AN (Army Navy) size. -4 is roughly 1/4". -8 is 1/2". -16 is 1". And so on and so forth.
  11. Grayguy
    Grayguy Well-Known Member
    ^ that's the same setup I have basically, -4 for the feed, and 5/8's return that's got as much metal in it as I could get to work well. Also from Northern Engine in duluth. Jay is the Man!
  12. Frogy
    Hey everyone, thanks for the great info! I was almost thinking silicone for the oil return, still not sure?
    frogy
