turbo question
Discussion in 'General Subaru Discussion' started by Squiggly, Nov 7, 2005.
  1. Squiggly
    Squiggly Squiggly
    Sorry if this sounds stupid but its really been bothering me.
    Why would 10 psi from a tiny turbo give you less power then 10 psi from a bigger turbo? isnt 10 psi 10 psi? can somone explain this
  2. 95lwrx
    95lwrx Well-Known Member
    easy, the amount of airflow, from a tiny turbo won't be as much as a larger turbo at same psi, this is where manufactuer flow charts come in handy.
  3. Squiggly
    Squiggly Squiggly
    thats what i was thinking but it still kind of seems confusing to me
  4. Dynapar
    doesnt the smaller turbo have issues when pipe size and other factors increase?
    so the smaller turbo can flow 10psi, but the CFM is lower becuase it will need smaller pipe diameters to reach 10 psi?
  5. Squiggly
    Squiggly Squiggly
    i dont get it
  6. AWDimprezaL
    my tiny turbo is gonna school all of you, you are all going down! :D :lol: ;)
  7. Squiggly
    Squiggly Squiggly
    stop going off topic and answer my question
  8. 95lwrx
    alot of the older factory turboed cars that used small turbos actually ran pretty high boost, but the don't gain that much more power. for example on my car the stock turbo tdo4 at 12lbs compared to my vf28 at 12lbs there is a very noticable difference in power just because of how much more cfm the vf28 pushes compared to the td04
  9. Dynapar
    ok, thats kinda what i was thinkin. since the turbo is bigger it can flow more air @ the same pressure as a smaller turbo.
    so even though they fwo the same PSI the larger turbo will push more air into the motor, becuase it has a a higher CFM rating.
  10. 95lwrx
    exactly :D
  11. Dynapar
    <--- Gold Star!
  12. WRX1
    then you can add efficiency and other factors into that.
  13. Squiggly
    Squiggly Squiggly
    kk thanks, now im off to prove my friend wrong
  14. TSTRBOY2004
    think about it.....
    blow through a hose... it is only so big and only enough air flows through...
    get a frain pipe or 3in pipe and a mouth like mivk jagger and you could mover more air through it... yes it may be only 10 psi each but the 10 psi in a garden hose compared to a 3in piping is a huge amount of air movement difference.. hence more power... hope that kinda explains it... not the most technological but practical if you ask me
  15. Cole
    Cole New Member
    But isn't the pressure isn't measured within the turbo...?
    If your post turbo piping is a constant size, how would the size of the turbo change to amount of air at certain PSI is? If you put 10psi of air in a box, it's 10psi, whether your or Mick jager put it there.....Mick would just have to work less.
  16. Dream
    lol
  17. LVT
    LVT Well-Known Member
    its like he said, the bigger the piping, the more air it takes to create the same amount of pressure. a bigger turbo has a bigger volume and will hold/push more air compare to a smaller turbo.
  18. bluebaru06
    bluebaru06 New Member
    Remember that the turbo itself is considered part of that pipe that Mick is blowing on so if it's a small turbo it will have a smaller inlet and outlet and therefore a lower cfm rate at the same pressure. Think of the straw and the rain gutter, twist them into a crazy straw and that's the turbo. The diameter of the straw and the drain pipe don't change when you make a crazy straw out of them.
    Stupid analogy concluded, now I'm gonna go drink beer through my crazy straw...cause I can.
  19. MNAutomatic
    MNAutomatic New Member
    Think of it terms of water. Which pipe is gonna allow it to flow quicker? Its kinda like a water wheel on a river if you really wanna get crazy. If you set up two pipes into a water wheel the one with the larger diamter will move it quicker because more water is hitting it. If you changed the water wheel to a turbine and the water to air the same thing occurs. The larger the piping the quicker it will flow because of less restrictions. Does that make any sense to anyone besides me?
  20. Cole
    Cole New Member
    But the intake manifold is always the same size...
    Ok so how about this...
    You have a 10 foot tall turbo, blowing into a 3 inch tube
    You also have a 2 foot tall turbo, blowing into an identical 3 inch tube
    you measure the pressure in each tube.
    Are we saying that if you spin the turbos so that both gauges read the same PSI, that the one for the bigger turbo will somehow be pushing more air? would it not just be more efficient (spining slower)?
  21. Zola
    Zola Well-Known Member
    Think of pressure (psi) independently of volume. If you had the equipment to do so, you could seal up the Metrodome and pressurize the entire volume of air inside it to 10 psi. Or you could pressurize the volume of air inside a soup can to 10 psi. The pressure of both would be identical, the volume, and hence MASS of air inside each would be drastically different. Now think of those volumes of air entering an engine, getting matched with appropriate amounts of fuel and having a spark applied.
    One of those volumes/masses of air will give you eleventy squillion horsepower. The other would get owned from a dig by a Segway.
  22. Cole
    Cole New Member
    I think I’ve got my problem. I’m thinking of it as the turbo pushing air into an enclosed space to increase the pressure, instead of the turbo itself compressing the air.
    So the bigger turbo can compress more air to Xpsi than smaller turbo in the same amount of time.
  23. WRX1
    true.
  24. Dynapar
    but the 10' turbo would not have to spin as much to keep the same pressure as the 2' turbolol this is turnign into a huge mess, and did blubaru06 say e was gonna drink beer through his turbo?
  25. WRX1
    well, you still have efficency to think about. Just because the turbo is larger doesn't really mean that it will flow more (aka the custom vf22 problem). What you need to do is figure out a performance level you want to achieve, and select a turbo that can get you to that area. So for the original question, Zola hit it right on the head. The rest of the questions are digging alot more into the turbo as a whole (hot and cold sides). That will open a whole new can of worms.
  26. powerlabs
    powerlabs New Member
    I still don't see an acceptable explanation here.
    Whatever size your turbo is, they all push air through the same restriction; the throttle body. And if the pressure is measured at the intake manifold, then 10PSI is 10PSI and that is the end of it. The reason why there is boost in the first place is because you have more airflow than the engine can ingest, so air backs up and pressure builds. It should not matter if your turbo can flow a million CFM, because if your engine only consumes 100 and boost is set for 10PSI, then the turbo can not be flowing one million CFM, ever.
    I've pondered this question numerous times and have yet to find an acceptable explanation.
  27. Zola
    Go ride in an STI that has a TD-04 turbo, boost limited to 10 psi. Then swap out the TD-04 for an FP Green or something, limit boost to 10 psi again, take a ride.
    Come back and see if you still say "10PSI is 10PSI and that is the end of it"
  28. Zola
    This thread is relevant:
    http://forums.nasioc.com/forums/showthread.php?t=739466
    Obviously there are a lot of factors at work here. The size of your motor, the relative size of two turbos being compared, how efficient each turbo is at the desired boost level, how hot/cool of an intake charge each turbo can produce, etc etc.
    But this guy tried putting a stock WRX turbo on a built 2.4L motor. Result? He couldn't make power with it (surprise surprise). The motor can take in vastly more air than this turbo can supply, it was sucked completely dry and couldn't produce more than 9 lbs of boost. Now if you put a turbo on that motor that is properly matched to the displacement and flow characteristics of the engine, CLEARLY you are going to be able to make more power even at only 9 lbs of boost.
  29. WRX1
    well, the next can of worms has been opened. if you are talking JUST TURBO'S, then you can get into the fact that the larger turbo will flow more air (read mass). Now you are talking about motors and throttle bodies and such, now you get into the other half of the turbo. A perfect example is the last dyno day we did. of the 5 people on the dyno that day, 4 of them had a 20g varient. One had a larger turbine side and he put down the most power (even had 91oct). Now we are getting into how efficient the turbo's hot side is. There is also the PR ratio that needs to be watched. lets take the 2.0l wrx. the turbo will flow 340 cfm. Now, the motor itself will easily flow alot more air than that. You main restriction is going to be the exhaust housing of the turbo. Now say you bump the turbo up to a super16g that flows around 575 cfm. The hot side of the turbo is still the restriction, BUT it is alot larger than the td04 so your motor can process more of the turbo's air. I will let even suck that up for a while, and I will finish a bit later. Cuz your next questions should be "why can't we just put a huge hot side on every turbo".
  30. Cole
    Cole New Member
  31. WRX1
    Well, you need to match the hot side and the cold side together to get a good pr ratio. If you put to large of a hot side on a turbo, you will get alot of lag. So you really need to find out what kind of spool you are looking for and match your power goals and spool to a turbo.
