Turbo Timer Install...
Discussion in 'Modifications And Maintenance' started by k_thaosta, Apr 2, 2004.
  1. k_thaosta
    k_thaosta Well-Known Member
    I just recently got a new tt and i really don't know where to start...
    I've found numerous install instructions on the nasioc forums, but they seem to have few pictures and descriptions... only thing that i'm kinda confused about is the wires... does anyone here know which wires to cut/splice?... I have the harness... it's a greddy tt...let me know
    Thanks
  2. WRX1
    With the harness, don't you just unplug the tumbler (key) harness?? If so, thats pretty easy. Just follow the key tumbler till you get to the plug. If you need any help, let me know.
  3. k_thaosta
    it's plug and play, yes with the harness.. but the factory alarm and the keyless is where it gets confusing...
  4. Gspot
    Gspot New Member
    scoobymods.com has a good howto
  5. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by k_thaosta
    WRX or STI
    I know what you need to do But I would highly recomend you do not cut any wires! I disassembled the the pin connectors and just pulled out the pin from the connector and taped it up.
    there are two wires that need to be disconnected one on the sec. system and the other is on the keyless entry. Realy an easy job just time consuming to do it right.
    Matt
  6. k_thaosta
    gotcha matt, but which wire is the one that connects to the pink wire on the car(the one that kills the engine if the ebrake is down)?.. i have a greddy tt..
  7. bikerboy
    Just pull the center console and you will see the wire connected to the switch on the right side of the E brake.
    M
  8. k_thaosta
    it's installed now, just can't figure out the ebrake thingy... oh well...
  9. bikerboy
    If you would like help with the "E-brake thingy" let me know
