Turbo?
Discussion in 'Modifications And Maintenance' started by Speedemon, Feb 21, 2006.
  1. Speedemon
    Speedemon Well-Known Member
    What should I get and should i just mod my stock injectors?
  2. Speedemon
    and dont ask what i want out of my car just pic what you like....
    and my RA gears are on the way, those should be in soon...
  3. powerlabs
    powerlabs New Member
    Stock engine block? I wouldn't go with anything more than a VF34. People pop those blocks all the time trying to push big power; its just not what it was designed to do. If you want to chance it a little more you could go with a VF22. I wouldn't bother with the 16G; a lot more money for not much extra performance. I definitely wouldn't touch an 18G unless I had internals.
    Personally I am upgrading from a VF29 to a ported polished and ceramic coated VF22. The VF29 was pretty fast (12.6 1/4 mile) and I am hoping the VF22 will be even better without a lot more lag. I'll let you all know how it goes.
    Check the link below for some turbo comparisons.
    http://www.projectwrx.com/modules.php?name=Content&pa=showpage&pid=33
  4. MNAutomatic
    MNAutomatic New Member
    You can do an 18g man. That is what I have planned for my 03 WRX this spring. I am so excited for the power
  5. Sogonerg
    Sogonerg Anteater
    You can go with any of those turbos, but you won't get the full potential power of the 18g w/ stock internals and block.
  6. readymix
    VF22 dude. 18G is huge, although I believe Russ is running one. VF34, well, I can tell you that isn't worth your time...nice turbo, makes you faster, but you end up wanting a little more. 16G? I'd take the VF22 over a 16G.
  7. Dream
    Super 16 hands down.
  8. Justin
    Justin Well-Known Member
    ^agree.
  9. Musashi
    I started out with a DB TD04, and than moved on to a VF34, that was definately not enough. Now I have a DB S16G w/ecutek and mod injectors. It cost more than all the IHI turbo's, but not that much more, and it has more potential, plus its rebuildable and consider the fact that with a little bigger turbo you can make more hp with less psi, which should equal reliablity. Everyone that has riden in my car at DCTC has came out with a smile. The DB S16G is just a few CFM's less than DB18G.
  10. MNAutomatic
    Do you really think an 18g is worse than a super 16? I have done so much research and have read that the 18g is a way better choice. Guess its different for a 4eat since the gearing is so much longer. We'll all get to see at the dyno day, if I am lucky enough to get in, what the 18g can do on a 2.0
  11. WRX1
    Since you are going with the ra gears, I would go with the super 16g. You will get 5-800 rpm quicker spool than the 18g and you will have close to the same flow.
    As for 18g and stock internals, that is all myth. I have been running 21-22 psi daily driven 18g for 2+ summers and haven't had 1 problem. I think I have about 10,000 miles on my current setup.
  12. bikerboy
    Auto's keep turbos spooled because of the torque convertor. I would say 18g on an auto and a s16g on a 5mt on a wrx
  13. MNAutomatic
    Good deal...I am placing the order today for the 18g. I am so excited for the power.
  14. Speedemon
    You think i could beat a corvette if i got any of these turbos?
  15. JiDM_WeRX
    JiDM_WeRX Well-Known Member
    I beat my friends C5 last year in the quarter numerous times..
    .and I have the stock turbo.
  16. Dream
    What kind of vette? Maybe a stock auto :lol:
  17. WRX1
    what gear set did you go with?? i tuned a 1820 with a (I think) ra gearset, and by time it built full boost, you werre are redline. If you wan't some good quick streetability, go with the 16g. it will spool quicker than the 34, flows more than the 22. I wouldn't go with the 18 just cuz of where the boost starts to come on. if you want a drag style car, go with the 18 or even the 20 and do some port work.
  18. Speedemon
    I am getting the RA gears. Would you go with the 16G or super 16G?
  19. Speedemon
    I think i might just get a VF22 and a FMIC to go with it....
  20. WRX1
    I would go with the monster super 16g. You will have very quick spool and almost the same power as the 18g. I wouldn't even mess around with the ihi turbo's, unless you are looking for something real cheap.
  21. JiDM_WeRX
    how much does a super 16g go for?
  22. Speedemon
    so can you give me a good tune? And can you get modded stock injectors? PM me...
  23. WRX1
    Ya, I can tune it, that isn't a problem. As for the modded injectors, I don't have any sitting here right now. If you run accross a set, or have a extra set I can mod them for ya. I went through witch hunter last time I did some injectors and I got them back in like a week or so. Hell, if you can get the ones out of your car I can mod them and get it all flowed and such. Just let me kow what you want to do.
  24. Speedemon
    Can you pm me a price for the injectors to get done and a tune?
