turning rotors? any recommendations?
Discussion in 'Modifications And Maintenance' started by illegal2.2, Apr 18, 2007.
  1. illegal2.2
    illegal2.2 Well-Known Member
    looks like my oem rotors are starting to warp. anyone know of a reputable shop that can turn them? lmk
    choung
  2. Nuke
    i take mine to checkers, 10 bucks each
  3. PhilSine
    PhilSine Well-Known Member
    Sometimes they cannot turn out the warp so be prepared to buy new rotors. If it were me, I would not even take a chance and just buy new ones anyways.
    How many miles on the OE rotors?
  4. illegal2.2
    probably 40k+
  5. AWDimprezaL
    Should be ok 2 turn
  6. Deride
    I turned my stock ones once with success, they were slightly warped too. Now I switched to brembo blanks which were $50 each for my 4 pots that I got.
  7. WRX1
    You probably have pad deposits on the rotors. HIGHLY unlikely the rotors are warped unless you have been doing some serious track days. Its just not going to happen on the street unless you drag the brakes for many miles.
  8. webcrawlr
    webcrawlr Well-Known Member
    Why not just get new ones and not worry about if it will fix it? The "cheap" ones at Napa are under 40 a set I think.
  9. PhilSine
    Webcrawler's right about new ones being inexpensive.
    With only 40k on the OE rotors I'd probably turn them and get some decent ceramic pads. Checker Auto sells Raybestos Quiet Stops for $56 a set.
  10. AWDimprezaL
    okay no, its extremely common for subaru rotors to warp, expecially in larger cars like legacies, there is nothing special about subaru rotors that make then resistant to warping. maybe not so much on the sti though.
  11. illegal2.2
    from what i read and researched, oem rotors(turned or not) can last a long time compared to napa,autozone,etc...
    choung
  12. shineynitelite
    dont listen to this guy. normal drivers can feel rotor warp with a difference at any point of the rotor at .002" it happens on EVERY car, no matter how you drive it.
  13. TSTRBOY2004
    cause they can be warped straight out of the box.. we have had to turn brand new ones on occasion... and $10 to turn a factory one compared to $40 is still $60 cheaper in my book... thats one reason....
  14. TSTRBOY2004
    sorry to burst your bubble.. but Russ is correct... but just not exactly 100%.. i would say 98% ha ha ha
    it can be warped due to cheap material used in most rotors nowadays, but mostly it will be a combination of both pad deposit and warpage from heat retention
  15. bummpy
    bummpy New Member
    Less talk talk, more read: http://www.stoptech.com/tech_info/tech_white_papers.shtml
    This is about the third time I posted this.
    Yes, and yes. And as russ said, unless you're seriously beating on these things in Nürburgring fashion, you are probably more susceptible to pad build up than rotor warpage due to massive heat retention.
  16. shineynitelite
    and an untold number of discs with pad material unevenly deposited on the friction surfaces
    this is whats known as 'warped', out of parallelism, or lateral runout.
  17. TSTRBOY2004
    or as they tell you at a dealership.. your rotors are 'GLAZED'...... as they willbe 5 mins after machining them...
    OP - go get them mic'd then if enough meat left... get em turned...
  18. shineynitelite
    minimum is .87" i'm turning my old ones as we speak.
