TW: GC coilovers, koni inserts
Discussion in 'For Sale : Car Parts' started by xxtraloud, Jul 13, 2008.
  1. xxtraloud
    xxtraloud New Member
    I just wanna see if anybody would be interested in coilovers that came off a 99 RS, and that I think would fit legacy's and other GC MY.
    I don't have pictures yet because right now I am sanding and repainting the struts with a few coats of primer and anti-rust paint, unfortunately today with this F wind I am not gonna be able to paint them.
    The set-up I have has KYB/Subaru struts, Ground Control sleeves and Eibach springs with Koni inserts.
    The springs are rated 340lb Front / 300lb Rear
    From what I know the set-up was used for about 5k miles.
    I also have an extra pair of Eibach spring rated at 250 lbs/in
    PM me if this might interest you.
  2. slobright
    slobright New Member
    Are these adjustable?
  3. EtchyLives
    EtchyLives Well-Known Member
    I like this setup. A lot.
    What height are the springs? 8"?
    These should bolt right up to any BC Chassis Legacy from 93+. I might be interested.
  4. xxtraloud
    yes they are adjustable. The Ground Control sleeves, that's their job. They are a good compromise because can be used for DD and also autox.
    I am pretty sure the springs are 8" because their initial code is 0800 according to the Eibach website.
  5. slobright
    Ok then count me equally as interested.
  6. BBsRS
    BBsRS Well-Known Member
    PM me how much you would like to get for these.
