Twin scroll flapper/ helper for single scroll mani....
Discussion in 'Modifications And Maintenance' started by Tdagen, Oct 6, 2009.
  1. Tdagen
    Tdagen Well-Known Member
    [​IMG][/IMG]
    Some may have seen this over on nabisco but I thought why not bring it to mn subarus attention ....
    I may very well use one of these with a Borg Warner s362? ( I think it's s362 whatever is as good or better than a 35r ts....) What do you guys think?
  2. JasonoJordan
    what would the use be why does it not cover both outlets? i guess ive not read anything on it so i do not know how it would work.
  3. Tim the Plumber
    im guessing this limits the flow path of the exhaust for quicker spool up at lower RPMs... but thats just a guess
  4. KA-T_240
    KA-T_240 Well-Known Member
    What would the purpose be of using one of these? What controls the flapper from being open vs. being closed. If you are that concerned with spool, why look at such a large turbo.
    If you are wanting to use a S362 you must want some very large power numbers.
  5. AWDimprezaL
    It might work off of vaccume, but probably works off of boost.
    Edit: the way the actuator sits it works off of boost.
  6. KA-T_240
    Did some google searching. It brought me to a thread on nasioc that contained this post:
    The guy is comparing adding this flapper valve to a turbo on a twin scroll to a variable vain geometry turbo ,like what is on the Ford Powerstroke trucks. I guess I don't see how its the same. I am trying to find pics of the inside of one of these turbos, but have not had any luck. I guess I will have to hope there is one at the shop I can take apart this week and take pics to show how it works. Its a really cool idea, the vanes that are in the exhaust housing end up having lots of problems with sticking, which leads to alot of people spending lots of money on turbos. I have been wanting to try one of them on my 240 for a long time!!
    Video of the VGT exhaust housing:
    http://www.forddoctorsdts.com/articles/video/turbo-recon.mpg
  7. KA-T_240
    Ya, it looks like its controlled by a "wastegate" if you want to call it that.
  8. Tdagen
    So your 1.10 hotside will become a .55 until you spool up and that flapper opens then you get back to the 1.10 for big topend... Sorry I couldn't post more info I was on lunch.
  9. piddster
    Like NSFW says, you are basically giving yourself two different A/R's with that flapper so I like the term bi-geometry. According to that dyno plot, it apears to help a bit, like 300-400 rpm.
    Not quite the same as a true variable geometry turbo like the VNT Garretts and VGT Holsets which have a much greater affect on spoolup.
  10. Tdagen
    This will only work with Twin Scroll turbo's though... What do you guys think?
    Run the big 1.10 A/R and get it to act like a .63 A/R...:)
  11. Tdagen
    So which Borg Warner is as big or bigger as a ts 35r and spools like the ts 35r ? I have trouble reading the compresor maps ect and not many subies run bw it seems, s300 362 or the 366 ?There is also a ton of A/R's to choose from too....
  12. Shibbs
    So this will basically make a twin-scroll turbo on a single scroll manifold act like a sequential turbo?
    This could be interesting.
  13. Tdagen
    Yes I think that is what it would be, let me assure you this will get interesting.....
  14. Tdagen
    I am basically looking to get Ts bw 35r equvilent to spool just a hair slower than my single scroll 3076 .82 is spooling now... That's the goal , if the goal isn't met: n2o to spool the thing or I am going to have to talk fobia into Fabbing me a ts manifold for some$$$$ :)
  15. fobiawrx
    fobiawrx Fabiola
    this thing wont work for us really. we mostly use t3 flanged turbos. if someone did use t4 flanges it would already be a twinscroll manifold and you cant use it and you allready have the gains if done right. you could always cut and weld a flange on but with all the fab work of re doing everything to accommodate the bigger turbo you might as well go twinscroll any way. this would work more for the 6-8 cylinder guys that already have the t4 flanged headers.
  16. fobiawrx
    fobiawrx Fabiola
    let me know. i will have a couple of headers for you to choose from once we get done with testing.
  17. Tdagen
    NICE! I would be interested in the TS headers and the up pipe :yumyum:... What size borg is 35r material the 362? right? Thats what I am thinking s300 362 T4 TS with maybe the .90 A/R...
  18. Tdagen
    Or is it the s300sx 83-75? Thats closer to the 35r ts
  19. fobiawrx
    fobiawrx Fabiola
    you might want bigger when you see how well they work.
  20. Tdagen
    I was thinking I want to get as close to 30r spoolup as possible lol... I should just man up and go 366 but.... I really want something like 4100rpm I don't lke to wait too long for the boost...
  21. fobiawrx
    fobiawrx Fabiola
    a S300SX 83/75 is a 35r size turbo. the S300SX 88/75 id a little bit bigger around the 37r size. a S300SX 91-79 is a 40r sized and what we use in our kits. vary common to have full boost before 4 grand. those are the signature airwerks turbos that we use. the s3## stuff is the bullseye labeling. bee's car will be tuned shortly and show how drivable a big turbo really is.
  22. Tdagen
    Ok which one is vary common to see boost before 4000rpm? I can't wait to see the results on bee's car, it has the 91-79?
  23. fobiawrx
    fobiawrx Fabiola
    all three i listed. even the 40r version
  24. Tdagen
    Holy &^%*... You serious the 91-79 even now we are talking... Maybe I will think about that lol....
  25. RichWRX
    RichWRX Well-Known Member
    we should be putting another header on my car soon, will let you know how it goes .^
  26. Tdagen
    Cool, one thing though does the header fit around the wrx oil pan? Ive got the 2002 bugeye
  27. RichWRX
    I think Matt was going to make some that did.
  28. fobiawrx
    fobiawrx Fabiola
    the one on riches car and bees car both fit around that pan. as well as dipps, aj's and evans at this point. evans and aj's most likely will change to the sti style header for fog light testing
  29. Tdagen
    Cool I can't wait to see / hear more... I was thinking , I don't think I can pass up the 91-79 ...I would have plenty of headroom, I meen I would never have to buy another turbo again...You know where I can find these turbo's for a good price too I bet?
  30. fobiawrx
    fobiawrx Fabiola
  31. Tdagen
    Oh yea that's aj right ... Cool now I am getting pumped, I am supposed to get stoptechs bbk and an aem em this winter but I may skip the aem , stick with romraider and go TS instead.... Mwah haha, feed the addiction....one more question fobia lol what kind of # per min does the 91-79 flow?
  32. Tdagen
    Also iirc when I looked at the AR website he has the 300/362 300/366 ect.. Are these the same turbos with different names that's what you ment ? Or do I ask for the 91-79 specifically ?
  33. Tdagen
    Does aj carry the signature airwerls turbos? Or are his bullseye, which are different...?
  34. Tdagen
    91-79 flows a whopping 82lb/min :eek4: :ugh: :eek: :) :biggrin: :biggrin:
  35. fobiawrx
    fobiawrx Fabiola
    aj can get both. you tell him you want the airwerks stuff with the .95AR and you would be good to go
  36. Tdagen
    When are you getting bee's car tuned? I wanna see what it puts down , is it going to be low boost ( 18-20psi or so)? These sound pretty swweeett to don't they... Dipps car sounded like a fighter jet in the video...
  37. dipp
    dipp Well-Known Member
    I made full boost @ 4,100 on my kit with some issues. when I get my chimera ported heads I should spool sooner. I'm running the Borg S366 .90 AR
