I say seafoam. The hood is up, and the smoke isn't blue. Turbo motors aren't known for headgaskets so much. Even if a headgasket was popped, it wouldn't pour smoke like that at idle. It would overheat. If it was that bad, I'd expect some pretty narley noises and a subsequent video. At least, I hope I'm right. BTW, Nathan, I need to come play with your welder. I got your number from Eli. I'll give you a call this week.
There was lots of smoke at Car Craft this afternoon. If I didn't smell tire smoke for a month I'd be happy.
I don't run cheapgas that clogsup the engine... Also hard to hit the gas and stand behind the car....
Whether or not you tend to burn your toast or Pop Tarts, your toaster can be subject to carbon and crumb buildup over time. You can either let it sit until it starts smoking or catches on fire or you can give your toaster a good cleaning once a month.
