Ultimate 2.5RS/Legacy/EJ25 turbo kit
Discussion in 'For Sale : Car Parts' started by PHATsuby, Jul 12, 2005.
  1. PHATsuby
    PHATsuby Well-Known Member
    Hey All,
    I am selling off my current turbo setup to make way for my next project. I am going to be gone until mid-august away from my car, so all of this will be available at that time.
    Here is the setup i had on my 2001 legacy GT, which in my opinion is a very good one. I have been running at 11psi daily on stock NA block for past 3k miles no issues, recent compression test showed exact same compression as before(all above spec):)
    Turbo Kit:
    garrett T3/T04B turbo
    Ludespeed 2.5" catless downpipe(made to work with auto trannies, will also work with manual trannies)
    Ludespeed uppipe(made to same specs as above)
    Spearco TMIC bar and plate core 6x18x3
    wrx 420cc injectors(can be modded for higher flow if needed)
    wrx injector adapters(allows use of top feed wrx injectors in NA manifold)
    Tial 38mm external wastegate
    Blitz Direct Drive Blow-Off Valve
    J&S Safeguard Version 1 with knock sensor(individual cylinder knock retard ability)
    Ludespeed oil pan with welded return tube
    associated hose clamps, fittings etc...
    Engine Management:
    Autronic SMC 2.0 with custom subaru dwell chip, reluctor interface and boost control
    the autronic is a complete stand alone ecu, but can be run in parallel to stock ecu(which i did) it has subaru trigger info already programmed for old and new triggers(previous and new wrx triggers), has temperature compensation for fuel/timing/boost maps features the great Autotune function which can be done with a wideband 02 sensor, helps tune low load areas fast. With this ecu your car can have stock startup and reliability even with an aftermarket kit, i will include my base maps as well for you to tune from.
    Exhaust(BE legacy specific)
    Brullen 2.5" catback, quiet acoustics single tip
    All of this cost close to 7k, the Autronic setup was over 2k by itself.
    All parts have approx 7000 miles, turbo has no shaft play.
    I would like to sell it all together(minus exhaust). 3750 pick-up
    or individually(will not separate kit into parts)
    Turbo Kit:2250
    Engine Management:1590
    Exhaust:375
    here is a pic of my engine bay
    pic of autronic(yea i know the wiring is all over;))
    let me know if you have any questions.
    thanks
    Ben
  2. Dynapar
    wow thats a huge wiring mess in your glove box. its gotta be like one of those snake in the can gags for the passenger lol. why do the up/downpipe need to be custom made for an auto tranny? would they run the same course for auto or manual?
  3. PHATsuby
    its not a mess in the glove box, its neat in there, just messy under the floor;) the auto pipes have to be custom because the normal routing and wastegate setup for a manual tranny will not work on the auto because it will hit the transmission due to the different size.
    Ben
  4. Speedemon
    Speedemon Well-Known Member
    are you getting ready for the engine swap
  5. PHATsuby
    yea, but not getting ready as in about to do it, it will still be a while, obviously if i had my way i would be doing it right now, but first this stuff has to go.
    Ben
  6. Dynapar
    is that ti-83 plsu graphing calc part of your engine management if it is i am TRULY impressed.
    also interesint to know that normal dps and ups wont work well w/ autos. i had assumed they were the same since you dont see different ups and downs from 5mt wrxs and auto wrxs. is it just that you cant clear the wastegate with the normal ludespeed parts, or are there other issues?
  7. PHATsuby
    the wastegate is in a different position to clear the tranny, that is the only issue i believe. obviously you dont see that on wrx's because they are smart and OEM;-)
    yep i use the calculator to help the autronic with calculations, and dont insult me with the Ti-83, its a Ti-89:D
    Ben
  8. Dynapar
    lol, so can you get maps for the 2.5l at ticalc.org?
  9. PHATsuby
    you sure can, it does my homework and runs my car too, great calculator.
    Ben
  10. Dynapar
    Bump for a wicked kit
  11. fobiawrx
    fobiawrx Fabiola
    are u back in town or r u staying away for the rest of your life?
  12. PHATsuby
    oh i'm back, where you at;)
  13. PHATsuby
    engine management is going to be sold, but mechanicals are left, who wants to turbo with a nice setup:)
    Ben
