Uncle Scotty's Cocktail Source
Discussion in 'Modifications And Maintenance' started by Zombie, Jul 30, 2007.
  1. Zombie
    Zombie Well-Known Member
    I did the uncle scotty's cocktail in my '02 and really liked it. I want to change the fluid in my '97 as it grinds going into 3rd. I stopped at Checker, Advance Auto, O-reilley's, and Napa and no one had the synchromesh or the HypoyC 80w-90. Anyone have a local source for this?
    *1qt Redline lightweight shockproof (already have)
    *1qt Pennzoil or GM Synchromesh (need)
    *2qt Castrol HypoyC 80w-90. (need)
  2. AspitFire
    gm syncromesh... go to your local gm dealer
  3. Justin
    Justin Well-Known Member
    i found it in the metro area..just cant freakin remember where. it was some where in st. paul at a major retailer.
  4. curly2k3
    which Napas did you go to, unless its a larger store or like the St. Louis Park store they probably wont have it
  5. prezawagon
    prezawagon Well-Known Member
    Pep Boys has hypoy C.
    Autozone has Penzoil Synchromesh.
  6. Justin
    yes!! pep boys is wher ei went
  7. wings_23
    wings_23 New Member
    Does this stuff really make a difference. You would think if it did, someone would sell it already made?
  8. ShortytheFirefighter
    It does make a difference, but you'd need to have a 5 speed to know. It's not recommended for the 6 speed.
  9. wings_23
    wings_23 New Member
    :eek3: OOOHHHH
    What do you recommend for the 6 speed
  10. blackozone
    Is that the actual cocktail recipe? I want to put that into my tranny, too.
  11. prezawagon
    Yeah, Put in 1 quart of redline lightweight shockproof and 1 quart of syncromesh. Then top off with the hypoy c.
    There's a bunch more info on nasioc, but I think that's basically it.
    I'm planning to try it in my transmission too, I just need to find time to run around to all the places and pick up the ingredients.
  12. stoooo
    stoooo Well-Known Member
    Yeah, I've been planning on this, too. I've got Red Line 75w90 in there right now.
    Are there really only 3 Pep Boys in the Metro area ? Looks like I'll be making a trip out to IGH sometime soon. Fortunately, Courtney Truck Service in Eden Prairie stocks all the Red Line stuff, so that's the easy one to get.
    Stuart.
  13. ShortytheFirefighter
    Yup, that's the recipe. Put in the Lightweight Shockproof and the Syncromesh first, and then top it off with the Hypoy C. You'll only need about 1.5 qts of the Hypoy C, make sure you don't over fill it. I've been running it for about 16k miles and it's worked great, the shifting is noticeably smoother.
    D'oh! Joel beat me while I was typing.
  14. Justin
    yeah it definitely works for teh 5 speed. i tried it awhile back and never went back to the oem crap
  15. blackozone
    Just be thankful you guys even have that stuff within close vicinity. Come try to hunt that stuff down in Roch...
  16. Justin
    i was thinking about buying a bunch of it up and selling it on our site
  17. blackozone
    Or possibly selling it in a pre-mix? That could be interesting...
  18. ShortytheFirefighter
    Ixnay on the premix, you're better off doing each ingredient seperately. Then you get all of the Lightweight Shockproof and all of the Synchromesh.
  19. pksublime
    pksublime Well-Known Member
    sounds like you could get it down to 2 bottles the first tow and the top off ingredient
    prolly not worth the effort though for only a one bottle reduction
    +1 on packaging it though
  20. blackozone
    I'm thinking more like pre-measuring (Overall fluid capacity - 1 litre of Syncromesh - 1 litre of redline = remainder for hypoy) and selling with the ingredients metered.
  21. Zombie
    I was going to suggest that actually. You could mark it up and I would still buy from you just for the ease. I ended up mailordering 4 quarts of the redline lightweight shockproof last year and driving all over hell to find the rest of the stuff.
    I wouldn't bother mixing it though.
    Do it!
  22. Nuke
    LSE carries redline fluids, just for those who don't want to order.
  23. Justin
    i could become a redline dealer but not for castrol or pennzoil...not sure where to get the last two cheaply
  24. ShortytheFirefighter
    One other thing as far as shipping it. It'll probably fall under a hazmat category since it's fluids, might require a HazMat certified shipper to comply with DOT.
  25. TSTRBOY2004
    well I ran synthetic... definitely smoother adn easier in winter.. but I switched back to dino after my gears in my rear diff went out after 10K on synth... I am of the school of thought that no synth in gears... my opinion / experience... what its worth.. who cares...
    pros and cons for both....
    I had a bad experience so I switched.. many others havent ....
  26. twiztid_rs
    twiztid_rs Well-Known Member
    i got one qt left of the redline in stock, bout 8 qts of the synchromesh in stock(by the way i work at advance auto if you didn't know), and o'riellys typically has the hypo c in stock thats where i got it from
    i'm off untill saturday so if you are on the south side check if the old rs is out there and swing on in
    jason
  27. webcrawlr
    webcrawlr Well-Known Member
    Naw, you can ship via USPS no problems. That's how Blackstone wants all its oil samples sent in. You just have to package it correctly.
  28. Frogy
    Frogy Well-Known Member
    Redline MTL is the same thing as GM Synchromesh, I have used it in Fiero transmissions with great results, I think its easier to get than syncromesh expecially if you already know where to get the lightweight shockproof.
  29. stoooo
    Ah, but does it have Uncle Scotty's seal of approval ? Do you really want to mess with success ?
    Stuart.
  30. Dynapar
    I wonder if this will help in my Brat... anyone know of anyone running scottys in a 4spd MT DR 4wd?
  31. readymix
    Is this cocktail a benefit for the synchros or the gears?
  32. prezawagon
    Syncros as far as I know.
  33. AWDimprezaL
    the shockproof is what helps the gears, ive been running straight syncromesh for a while now, i get a grind when its really hot in 2nd, but thats only when im hammering gears.
  34. blackozone
    LOL... I miss 4 speeds...
    Clashing and easy shifting are related to the synchros, normally. A whining from the gears (My first gear, for example...) is indication of the gears grinding each other up. You can get a grind from your differentials, too. Speaking of which, does anyone have recommendations for differential fluids?
  35. prezawagon
    Just for fun I checked and you can order all of the ingredients from amazon.
    Castrol Hypoy C, 2 quarts @ $6.99 each
    http://www.amazon.com/exec/obidos/tg/detail/-/B0002JMAL6/
    Red Line Lightweight Shockproof, 1 quart @ $8.25
    http://www.amazon.com/exec/obidos/tg/detail/-/B000J3G8MM/
    Pennzoil Synchromesh, 1 quart @ $8.99
    http://www.amazon.com/exec/obidos/tg/detail/-/B0002KL098/
    So the total would be $31.22 plus shipping
    Oh, and it's great how underneath "Customers Who Bought This Item Also Bought" on the red line shockproof page, it shows the other two ingredients of the cocktail.
  36. stoooo
    Looks like shipping to MN runs about $20. I think I'll look around locally for these. I'm tired of putting the FedUPS guys' kids through college.
    Stuart.
  37. EtchyLives
    EtchyLives Well-Known Member
    Which part to put in the rear diff? I'm pretty sure it's the Redline, but I want to make sure before I blow a few bucks I don't need to.
  38. Chux
    ha, yea, I'm sure someone here has tried it :laugh:
    but the 4-speeds use essentially identical synchro design to the 5MTs. just crappier linkage.
    I've switched to the cocktail, and noticed minimal improvement over valvoline 85w90 and rislone.....at double the cost.
    that said, O'reilley's here in Duluth had both the pennzoil synchromesh and HypoyC on the shelf
  39. SomethingsWrong
  40. Ryan
    Ryan Sled drifting master
    After getting pissed off that I can't find rev on the first, 2nd, or 3rd tries most of the time I think i'll be doing the cocktail this weekend. Car just hit 30k so it couldn't hurt. Sounds like I might be driving all over to find the stuff. Of course the phone works too for me ;)
  41. Ryan
    FYI, I just got both the 1qt Pennzoil and 2qt Castrol HypoyC 80w-90 at the pep boys in brooklin center. They had a bunch of the hypoyc stuff and just a couple bottles of the pennzoil. Also for the rear diff they had both moble 1 and royal purple.
    I haven't desided yet on what i'm going to throw in my rear. Tossed up between moble 1 (which i ran in my jeep), redline (which I also ran in my jeep and I have about half a bottle that is 4 years old, so I'd have to buy more anyways), or royal purple. When I do my tranny and rear end I plan on doing a full write-up with pictures because I figure it could help the newbies out there.
  42. curly2k3
    royal purple, i am always fond of how the stuff runs in my cars
  43. Dizmal
    Dizmal Well-Known Member
    Anyone have a good phone # for LSE? The one in the shop listing seems to be out of service.
  44. TRUBLU
    TRUBLU New Member
    Synthetic in gear boxes that don't recommend Synthetic...BAD as Nathan found out :( stick with 80w90 GL5 NON-synthetic. That way,. you only to swap the transmission and diff fluid every 30,000 miles...instead swapping out the entire transmission and rear diff every 10,000. Saves money in the long run :eek:
  45. Dizmal
    Is Redline 75w90ns synthetic?
