Uncle Scotty's Tranny cocktail mix....
Discussion in 'Modifications And Maintenance' started by jdmspecWRX, Sep 10, 2007.
  1. jdmspecWRX
    jdmspecWRX Well-Known Member
    Who knows how to do this and can help me out. I can get the supplies.
  2. blackozone
  3. Dizmal
    Dizmal Well-Known Member
    It is sex in a bottle(s)
  4. Sogonerg
    Sogonerg Anteater
    plz search :roll:
  5. stoooo
    stoooo Well-Known Member
    Going to be doing this on Friday.
    Stuart.
  6. jdmspecWRX
    sorry guys.........I got lazy again. Thanks for the info.
  7. Shibbs
    Its working great for my 07.
  8. Hawke
    Hawke Well-Known Member
    Did this for the 92x about a week ago. Definately feels smoother and easier to get into gear. The real test will be this winter when things get cold. It was very easy to do and well worth it.
  9. SubeN'Siren
    SubeN'Siren Well-Known Member
    I think another real test is after you've had it in for 6-7K miles...
    After I had my clutch done, I put straight redline (the one they recommend for our MT) worked great for about 6-7K, now I'm getting a grind going into
    5th more than 90% of the time.
  10. Justin
    Justin Well-Known Member
    ^i used it for about 30k miles on my wrx. worked like a charm the entire time
  11. SubeN'Siren
    I need to try it...probably see you soon, Justin!
  12. Back Road Runner
    If you want something simpler, try straight Amsoil Severe Gear 75w-90(also 75w-110 and 75w-140 available). I've been running it in my Forester for 2 years now, beautiful stuff, very usable during the colder months, and it doesn't get worse as time goes on. 2 years later, and it's as good as the day I put it in. I've never ground a gear once that wasn't from user(brain-foot/hand) error. Since we do run in pretty cold temps, it is nice to run a non-dino fluid that doesn't turn to jelly on those cold, cold days and Amsoil has the lowest pour point I'm aware of for any tranny oil, -60C, a good 30 degrees lower than a comparable dino like Castrol's Hypoy-C.
