up pipe= flex or no flex??
Discussion in 'Modifications And Maintenance' started by solomon, Feb 5, 2007.
  1. solomon
    solomon Well-Known Member
    well Im going to buy a uppipe and was wondering which is better, flex or no flex ive heard that no flex gives more air flow but ive also heard that flex was meant for the subaru so just getting peoples opinion.. Flex or no flex??
    thanks guys
    -solomon
  2. Sogonerg
    Sogonerg Anteater
    IMO Flex would be best...so it has a less chance of a crack/leak later on...But again, unless u pay $$$ for a no flex up-pipe u'll be fine too...
    I've got the GT-Spec headers which comes with an up-pipe but it isn't a flex one...But it is one SOLID THICK BEEFY up-pipe...Plus it is a 3 bolt so less chane of a leak fom where it conects...
  3. AWDimprezaL
    i vote flex too
  4. pbedroske
    pbedroske Well-Known Member
    You can get a solid one, just use good gaskets and copper/silicon sealant.
  5. Scuba Steve
    Flex- ability for pipe to flex during engine movement. yes, can be a benefit. However, I haven't seen too many cases where an aftermarket up-pipes has cracked.
    install- Having a flex up-pipe is easier to install without leaks. :hsugh: whatever. poor install is poor install.
    Buy a sti up-pipe. A) you'll never see it once installed on the car. B) a ton cheaper. C) Looks like stock up-pipe
    I have installed a few up-pipes and all were solid. No issues with any of them cracking or leaking...yet;)
  6. Sogonerg
    Sogonerg Anteater
    I've seen a few cracked Non-flex up-pipe, again quality wasn't there priority
  7. Scuba Steve
    What brand? I've only installed perrin, crucial, and invidia
  8. Sogonerg
    Sogonerg Anteater
    I do not know the brand of the Non Flex ones, but it was no where near what the GT-Spec Up-pipe ones. Also it reminds me, I've seen a flex one as well on Kuba's STi...He had the HKS headers with a flex up-pipe I'm 99% sure...They both were JUNK the headers leaked and the up-pipe cracked, it happened during the Tune/Dyno day from what I remember...
  9. WRX1
    ^^^^^ True statement. It wa a hks header and a hks uppipe in a daily driven car that didn't even last 2 years.
    Well, as for flex or no flex, I don't think it is going to matter. The turbo and uppipe get bolted to the motor, so the turbo is not going to move. So if you are not going to take your time and do a proper install, go with the flex. I have heard of flex pipes rotting for the inside out.
  10. solomon
    thanks for the info
  11. Shibbs
    What about an up-pipe from an 07? I know mine's catless.
  12. AWDimprezaL
    i wouldnt even worry about it till you are making BIG numbers
  13. Se7enrex
    Se7enrex Well-Known Member
    If you are gonna go, go NO flex-I havent heard many bad things(some) but Ive heard only good things about hard pipes:biggrin:
  14. MNAutomatic
    MNAutomatic New Member
    I had a flew Up pipe and had no issues but again the install is a crucial part of whether or not it leaks or has issues down the road.
  15. SomethingsWrong
    Forget the flex. Go with flow. :)
  16. ShortytheFirefighter
    This is really a non issue. Show me one chart where a flex or non flex uppipe makes that much more power that you should choose one over the other. Each manufacturer has their own ideas, I would just find a manufacturer that you trust or have done some research on. I bought my Prodrive pipe without worrying because I know they make a quality product. The OEM unit has a flex unit, the STI has a flex unit. That tells me there may be a reason for one. I highly doubt that a flex piece is going to rob you of any power. All the issues I've heard have been on solid pipes, not flex pipes. You're going to get an answer out of everyone on here that's going to be different, just take the advice you were given in your other thread and research different pipes and find the one you think you'll be happiest with. NONE of them are going to make a signifigant amount more power than another one, they'll all be within 1-2 hp. You can get the same gains as you would gutting your stocker.
  17. Sogonerg
    Sogonerg Anteater
    ^HP isn't gonna make much difference...Just buy a quality Up-pipe and your set...Flex or Not
