Up pipe?
Discussion in 'Modifications And Maintenance' started by solomon, Feb 1, 2007.
  1. solomon
    solomon Well-Known Member
  2. mnstilynwrx
    mnstilynwrx Well-Known Member
    get the erz up pipe. iam pretty shure any one will work. i will have one for sale in a while if you'r not in a hurry. helix is what i got.
  3. solomon
    for how much? i have an 02 wrx would any up pipe work? oh how many miles do you have on that helix?
  4. jdmspecWRX
    jdmspecWRX Well-Known Member
    I have a used Godspeed up-pipe for sale also. Good condition. $75 takes it.
  5. solomon
    i also have a question about used pipes? is still as good as new? when you get a used up pipe (or any other items) is there a decrease in power? how many miles you got on your Godspeed?^
  6. jdmspecWRX
    A used one is just as good as a new one, so there is basically no decrease in power whatsoever. I got this from a another member of mnsubaru last year. It was in his car for a year I think. I never had a chance to put it on. From what I heard about the up-pipes, the flex ones are not as good. Godspeed is a straight through design.....no flex section. ERZ's are flex as well as some others.
    I got a good deal on a brand new dp and up combo.....so I won't need this.
  7. bikerboy
    I would inspect all the studs on a used uppipe to make sure the threads are good. There will be no decrease in power, only an addition in spool up which gives more power. I would recommend looking at some form of engine management for your own safety before you install these parts.
    May the spool be with you. :biggrin:
  8. jdmspecWRX
    These brands are the best of the best in terms of quality, performance, looks, etc. You can't go wrong with either one.
    Invidia
    Helix
    Godspeed
    Cobb
    All others I would say are secondary.
  9. jdmspecWRX
    bikerboy, may the spool be with you....
    ha ha i like that......
  10. mnstilynwrx
    yeah get some engine managment like cobb or something.
  11. solomon
    i have cobb im currently running stage 1 i feels much faster! i just got my dp so i was gunna get a up pipe and install them both at the same time and run stage 2!:)
  12. wall of tvs
    lmao!
  13. mnstilynwrx
    ok then get what ever up pipe suites you. erz is a good a good bang for your buck or buy jdm's uppipe
  14. solomon
    ok thanks for all the help :)
    solomon
  15. ShortytheFirefighter
    When it comes to uppipes, I have heard the argument go both ways as far as flex joints. Some companies have them, some don't. My Prodrive uppipe has a flex and I have had 0 problems with it. The stock one has a flex joint, to me that says something...if Subaru wanted one there, perhaps they had a reason? Used uppipes are usually a good bet, find one in decent condition...I bought my Prodrive for 80 shipped and sold my old one for 40, so it was a pretty cost effective mod. You could also save yourself the coin altogether and just gut your stock pipe. It'll get you the same gains, just make sure you get all the substrate material out. There are several threads on Nasioc and Scoobymods on how to do this. If you decide to get an aftermarket pipe, if you find one you like do some searches and see if anyone has had any issues with that pipe. Good luck!
    I'd put a Prodrive pipe up there with any of the rest ;)
  16. bikerwriter
    bikerwriter Well-Known Member
    A used up-pipe would be fine. Just install both at the same time so you don't duplicate your work. As an impatient person, my recommendation is:
    You buy now!
