uppipe fitment
Discussion in 'Modifications And Maintenance' started by carbonfiber, May 12, 2006.
  1. carbonfiber
    carbonfiber New Member
    i was wondering if the uppipe i'm getting would fit my stock downpipe
    tsudo uppipe specs 3" all the way.
  2. TSTRBOY2004
    yes... because htey are 2 different areas... the only thing they both do the same besides exhaust is mount to the turbo... most aftermarket pipes will fit no probs if you take your time to do it...
  3. Sogonerg
    Sogonerg Anteater
    just make sure you get new gaskets with them...
  4. wall of tvs
    3" uppipe?
    Bigger isn't better in the case of an uppipe. ;)
  5. bikerwriter
    bikerwriter Well-Known Member
    Yeah, and the up-pipe is way more work than a down-pipe or TBE. If you are going to swap the up-pipe, best to make a weekend out of it and do both.
    Go TXS!
  6. jk78
    jk78 New Member
    I also suggest buying new studs or using bolts as it's cheaper than the frustration of extracting the old ones from the uppipe's turbine side.
    3"!!
  7. wall of tvs
    ....or you could just get a Crucial pipe that comes with studs. ;)
  8. jk78
    jk78 New Member
    You have a Crucial pipe too?? I do as well. yay for thermal coating! I didn't use my studs, I actually used bolts which seemed a bit easier to work with.
  9. carbonfiber
    what is a crucial pipe ?
  10. jk78
    jk78 New Member
  11. wall of tvs
    Arguably the best uppipe on the market.
