Uppipe heat management
Discussion in 'Modifications And Maintenance' started by SomethingsWrong, May 25, 2007.
  1. SomethingsWrong
    I am contemplating either wrapping my uppipe or getting it sprayed (no, I still don't have it in yet, I'm that sad) and was wondering what to use. I wouldn't mind trying to coat it myself if possible but I don't know what to use or where to get it.
    Give me some ideas/options.
    Thanks
    -Josh
  2. Justin
    Justin Well-Known Member
    dont buy the can spray on crap..especially for an up pipe. techlines thermal barrier is what we and alot of coating companies use. first you'll need to bake the part, then sand blast, then acetone, then coat, then bake again.
    after that i'd go ahead and wrap it. doing both coating and wrapping at the same time has its cons, but the pros more than outweigh.
    Justin
  3. Ryan
    Ryan Sled drifting master
    Newbie question: So the up-pipe that is on my car is not wrapped/shielded at all. Is this something I should be concerned with?
  4. Shane86
    Shane86 Well-Known Member
    No.
    it's just something that might increase performance a little bit.
  5. Justin
    so then that would be yes
    i've heard stories of people blaming their passenger side head problems on the up pipe because it sits so close to the engine. i could definitely see this happening when youtake off the stocker and put an unshielded aftermarket pipe on.
  6. Ryan
    time for googlesearch /mnsubaru search of heat wrap. :)
  7. Justin
    i have a ton in the shop..come on over.
  8. SomethingsWrong
    What do you guys charge on coating an UP?
  9. hella_sti
    hella_sti Well-Known Member
    I say spray it with vht ceramic spray paint and then wrap it with the dei heat wrap and seal it with the silicone spray.
  10. Justin
    20 bucks if you get it with our pnp service. or 50 if you just do the coating.
    go to the pnp section... www.grimmspeed.com/store
