taken care of i need a caliper for a 04 sti. right rear. some idiot stipped the bottom bolt help anyone.
Take the bolt out. I had one break out into the caliper bracket and I used a drill and backout bit. Worked great. I'd recommend new bolts all the way around after that happens.
that doesn't help my situation mine is stripped no threads i can use anti sieze cause there is nothing to bit into with threads and there is nothing in the hole.
Well it was an addition to the dill/re-tap. Replace bolts on both sides, and use antiseize... If the threads are totally gone, you should be able to step it up to the next bolt size, for example M12x1.25 to an M14x1.25 or whatever pitch you want to put in. www.mcmaster.com should have any drill bit and tap size you will need to do it. Next day shipping on everything.
