I will be installing a new turbo, injectors, fuel pump and short ram intake on Thursday,can i run in stock mode until I get it tuned on saturday? or do I have to change some settings. Thanks Rich
you will have to change your settings. The biggest thing is to get the fuel injector scaling set. You just need to get it pretty close, your ecu will compensate for some of it. Is the short ram a big maf?? What size injectors? Russ
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by RichWRX 850cc injectors, its the turbo xs short ram intake, you gona be there Russ? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> PE's?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by RichWRX perrin modified <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> Should be pretty easy then. All you would have to do to get it to idle is set the new injector flow to 850cc. I'd let Russ comment on that before actually doing it though...
ya, just set the mod injector scale to what they flowed at (I thought the perrins are around 820) and go from there. Your ecu will adjust the fuel trims from there. Just make sure you don't beat on it. Alsoi keep the boost down. Yes, I will be there. Russ
