V25B '07 STi cylinder heads
Discussion in 'For Sale : Car Parts' started by joebush44, Sep 22, 2016.
  1. joebush44
    joebush44 Well-Known Member
    Just got these back from the machine shop. Originally on an '07 STi. Valve job, new seals, decked and hot tanked. Zero miles. Complete heads with cams and valve covers. Looking to sell because I found a built long block I want.
    Can also include cam sprockets, new cam seals, and AVCS solenoids if needed.
    Still in the bags. Can open and get more pictures upon request.
    Asking 1200 obo.
  2. Ryan FailRad
    What cams?
  3. joebush44
    Stock AVCS cams
  4. joebush44
    Just FYI - These heads are easily interchangeable with the B25 heads found on 04-06 STi. The biggest difference between the v25b ('07) and the b25 ('04-'06) is that the v25b has the EGR passage for the air pump contraption they added in '07. A block off plate can easily and very inexpensively cover that hole. The other minor differences are that the exhaust ports a bit larger and the coolant passages were improved on the v25b heads (so you'd want to use an '07 sti head gasket). Other than that, they are identical. Same comp ratio, same cam sprockets. This info has been confirmed by Fuji.
  5. joebush44
    Sold
