So does anyone know if a Version 6 gauge cluster will wire in correctly with an L. Can i make it work? The picture i have attached is the gauge cluster i'm going to buy.
I'm pretty sure the ver 6 cluster will only directly plug into a 00-01. I'm not sure about the L, but I don't think it would matter. Good luck with everything.
I know the fitment will work perfectly but i don't know if it will be compatible. As far as i know my gauge cluster is mechanical and not digital. I want to convert my cluster into digital. I've seen the JDM Ver6 clusters on 1998 RS's with a few wires that needed to be rewired. Also they are complete bolt ons on 00-01 RS's. If anyone has any advice on installing this on the pre 97's PLEASE let me know!
they make converters that will convert the speddo cable signal form KPH to MPH. might want one of those or else learn the metric system well
I have the wrx one with the 7500 rpm tach. I just wrote down a cheat sheet for the kph to mph conversion and eventually memorized it. Or you could just remember that for every 5 mph there's 8 kph. So 50 is 80, 55 is 88 and so on
i don't care about changing metric to u.s. units. that's why i'm an engineer. i just want to know if it'll work for my 97 L wagon.
