VF-39 WRX Unstable boost Problem
Discussion in 'Modifications And Maintenance' started by T-REX5000, Sep 25, 2007.
  1. T-REX5000
    T-REX5000 Well-Known Member
    I just installed a VF-39 and 565 Injectors into my 2005 WRX and whenever I hit max boost...somewhere around 17psi the boost gauge starts to oscillate between about 16 and 19 up and down.
    I am thinking that this may either be the wastegate arm needing adjustment or maybe my BCS....
    any ideas???
    I did a search and didnt find anything.
  2. readymix
    If you still have your TD04, take the airline "T" assembly off and use it on the VF39. THe restrictor pill in the TD04 should fix the problem....
    I had this same issue on my VF34 setup. The restrictor pill from the TD04 fixed the problem.
  3. T-REX5000
    I believe that Justin over at Grimmspeed reused my T assembly. The stock turbo that I got back is bare of any vacuum lines
  4. wall of tvs
    What type of EM are you running?
    If it's a custom tune, your tuner sucks.
    If it's some sort of off the shelf map, make sure that your hardware (ie, restrictor pill diameter, bcs) is EXACTLY the specs required for that map.
    I can tell you right now that your wgdc map is too high for what you're running.
    Adding a GM BCS to an off the shelf map designed for the stock BCS will cause this. Using a restrictor pill with a smaller diameter that what an off the shelf map was tuned for will also cause this.
  5. T-REX5000
    I am using the VF-39/Deatchworks 565/STI top mount on my version 1 access port. I am however running a decent sized FMIC instead of the STI top mount. The map notes did not say anything about changing out the pill like some of the other ones did.
    I am also on the stock BCS. I was worried that my pill is too small. I am also reusing the stock "T" turbo assembly.
  6. wall of tvs
    Well there's your problem.
    The td04 uses a smaller diameter restrictor pill than the vf39 does. The pill is located in the "T" assembly on the compressor side of the "T".
    Find a vf39 pill and your boost problem should go away.
  7. T-REX5000
    thanks WOT....I will look for a pill and see how that works out.
    I guess the question is how dangerous is running the stock pill? I plan on taking it easy as to not overboost until I can get the right pill...should I order directly from subaru?
    someone probably has one sitting around
  8. wall of tvs
    The safest route would be to run a short vacuum line from the compressor directly to the wastegate actuator (and thus disabling the bcs) until you get the right pill. Doing so will cause the car to simply run wastegate pressure (depends on the wg spring, but I'm guessing it will be ~ 7-10psi).
  9. T-REX5000
    does anyone have a #57 drill bit I can use or an STI pill they are willing to let me have?
  10. idget
    ^Yeah I have 2 or 3 sitting around somewhere.
  11. T-REX5000
    sweet, ill come pick one up tomorrow or I guess as soon as your free
  12. Nuke
    LOL...i remember what happened :laugh:
  13. Dream
    For future reference, if you have problems with your car and a shop or person installed the parts, go to them first before you post threads.
  14. Iroc-Z
    Iroc-Z Well-Known Member
    Wow way to regulate
  15. Dream
    Just a friendly word of advice. ;)
  16. shineynitelite
    what do you know about that? dont you do all your own work!?
  17. Justin
    Justin Well-Known Member
    this is interesting..like readymix said above, i've used the td04 restrictor pill on other vf3x turbos and it worked perfect. i dont see how this could be different. lots of guys on nasioc do the same thing with no side affects. interesting...
  18. wall of tvs
    Uh, changing the diameter of the restrictor by even a few thousandths of an inch can have a huge impact.
    Bottom line is run the correct pill that your OTS map is setup for.
  19. Justin
    then how is it that many people have run the td04 lines w/pill when they do a 39/30/34 swap and it works properly?
  20. Nuke
    From Cobb's instruction, they said to take the td04 pill and drill it out
    But other than that, I haven't seen anyone run the stock td04 pill with the vf39, I think that would overboost
  21. wall of tvs
    Because they either got a custom tune or they are complete morons. I take most things said on Nasioc with a grain of salt.
  22. Hallywood
    Hallywood Well-Known Member
    like said above...wgdc are probably setup incorrectly as well if its a ots map
  23. idget
    It does overboost... smaller diameter on the td04 pill... no pill and you are running wastegate pressure... you can ask 1_sic_rex all about that
    yeah... and apparently if you run both the td04 pill and the vf39 pill on a vf39 swapped wrx with cobb ots map you get upwards of 21 psi... not that I'd know or anything...
  24. AspitFire
    what he said!
  25. T-REX5000
    Alright well I am getting the STI pill friday and I will try that. If I didn't have a boost gauge or know what to look for I wouldn't have noticed anything so maybe people have been having this issue but just didn't know.
    This issue in no way reflects Justin's shop...they did an awesome job on the swap. This is totally my error and is a cheap (heck, free) fix
  26. TSTRBOY2004
    True that!!!
    Unfortunately judging by Justins comments he wouldn't have had the answer of hand... just one of those situations where it works for some and not for others???? seems like a strange situation... hope the pill solves it all....
  27. T-REX5000
    oh it will...and if it doesn't I will do what I should have done in the first place.....CUSTOM TUNE!!!!!
    I just didn't have the $$$ to do it right away
