VF43 turbo
Discussion in 'For Sale : Car Parts' started by joebush44, Sep 8, 2016.
  1. joebush44
    joebush44 Well-Known Member
    Approximately 70k miles. Looking to sell this turbo, but want to be up front about it. I haven't ever run this turbo as it was on a motor I bought out of an '07 STi. It has zero axial (front to back) shaft play, but does have some side to side shaft play which I understand is normal on a journal bearing turbo. However, with a bit of pressure, it slightly scrapes the compressor housing. Hardly any side to side play on the hot side. I'm not sure the last time this motor was run so I'm wondering if the excess play on the compressor side is from the turbo being bone dry? I know journal bearing turbos need oil pressure to stabilize the wheel so maybe it will be fine once the motor is running. I was planning to upgrade the turbo anyway. Typical wastegate crack also.
    I don't want to sell something that isn't usable. If you're comfortable running it, make an offer.
    Oil feed and coolant lines not included.
    300 obo
  2. joebush44
    SOLD
