want to turbo charge my 2.2 HELP!
Discussion in 'Modifications And Maintenance' started by mikei, May 16, 2007.
  1. mikei
    mikei Well-Known Member
    so i want to make the legacy its a 96 with a 2.2 auto into a turbo manual.
    i want to know what i need and where to get .not looking into making it a race car used parts will do just fine/salvaged. all help is welcome
  2. readymix
    Talk to AWDImprezaL, he has a very stout 2.2N/A that he turbo'd.
  3. Colin
    Colin Well-Known Member
    why??? not trying to **** on your parade, I'm just really wondering.
  4. 02blubru
    PM awdimprezal or readymixx, they should be able to give you a lot of direction on this project.
  5. Dynapar
    There are several companies out there which sell bolt on turbo kits for the 2.5l which will work hand in hand with your 2.2l. Rallitek sells the AVo kit, theres FAT, and a few others. i have yet to hear a bad rap about any of these kits.
    if you want to piece together a kit on your own there is a little bit of research involved. do you want to use the legacy turbo x-member or just have a custom uppipe? do you want stand alone EM, piggy back EM or no EM? How much boost? What price range are you looking at for parts?
    good information:
    http://www.rs25.com/forums/showthread.php?t=3541
    http://www.rs25.com/forums/showthread.php?t=52607
    http://www.rs25.com/forums/forumdisplay.php?f=7
    as for the auto -> manual conversion. you will need tranny, clutch, shift linkage, pedal box, matching rear diff (depends on tranny, might be able to use the old one), drive shaft (unless going 6spd), cables and a few other things.
  6. AWDimprezaL
    YES pm me for more info, mine has been running like a top for the last 25K miles, and just received a bigger pump and injectors, w00t indeed.
  7. readymix
    And it recieved a bigger snail IIRC, big dawwwwg ;)
  8. AWDimprezaL
    yes forgot to add huge massive slimey snail, for MORE boosts
  9. Dynapar
    ^ still TD04 right? or did you go bigger?
  10. AWDimprezaL
    20g 15 psi.......kidding td04 10 psi
