Wanted: Impreza tophats
Discussion in 'For Sale : Car Parts' started by TRUBLU, Jun 6, 2007.
  1. TRUBLU
    TRUBLU New Member
    I need Impreza tophats.
    Wagon/Sedan/OBS.
    Doesn't matter what year after 1994
    Let me know what you have. I need them quick before my wheel falls off.
    Don't laugh! I'm not joking! Deride and wrxjoe can vouch for that!
  2. Deride
    Yes, he needs them. For the safety of his children someone sell this guy some tophats so he can get springs/struts in :p
  3. TRUBLU
    TRUBLU New Member
    lol, the first time I realised what the issue was....I banned the wife and daughter from the car. ATM their Saturn is safer then this pile.
  4. dman
    dman New Member
    I might have two front tophats for you with about 60-70k on them if I figure out how to install camber plates I got (nut/insert bushing that goes on top has a larger tread then needed, and I have to saw/machine off about 5mm off it to use oem nut to secure the strut rod).
  5. TRUBLU
    TRUBLU New Member
    Keep me updated dude!
  6. speedyham
    speedyham Well-Known Member
    Fronts or rears?
  7. TRUBLU
    TRUBLU New Member
    lol...both!
  8. wrxjoe
    wrxjoe Well-Known Member
    I don't see anything wrong with the fact that your car is probably still bouncing from your drive home from work this afternoon. It sounds fun to me.. But seriously you need to lift that wagon, how does a 8" lift sound?
  9. ShortytheFirefighter
    I have a set of 4 off of an 04 STI, about 12k miles on them. 60 bucks and all 4 are yours. Let me know.
  10. TSTRBOY2004
    you are still around....
  11. TRUBLU
    TRUBLU New Member
    Hey Brian, thanks for the offer, I will keep them in mind but I will be honest, it is a little hard to justify $60 for just tophats....I know they are from an STi but I can't see any real HP increase from them LOL
    Nate, yup, still kickin' and I must say that by using that avatar...you should be ashamed of yourself!
  12. dman
    dman New Member
    So the 04 sti rears will fit your car? I think those are very similar to 95-99 legacy rears, and have those laying around somewhere. They are well used, with like 100k on them, but I'll give them away for free :)
  13. TRUBLU
    TRUBLU New Member
    nah, I got the 99 tophats on the car already, I dont know if they will fit the Impreza springs, i will find out tomorrow if they will or not. but I was under the distinct impression that they wont.
  14. Yang
    Yang Well-Known Member
    i got 4 top hats, or if you want I got all of my obs suspension still intact. pm me if you are interested.
    yang
  15. gran0393
    gran0393 Well-Known Member
    ray if u need these moved from the cities up to duluth i'm coming back up on sat...i can pick em up sometime and run em up for ya...no charge
  16. ej20
    ej20 Well-Known Member
    Got two Rear ones from my 02 wrx sedan if you're interested. about 50K miles. Pm me if interested
  17. TRUBLU
    TRUBLU New Member
    Thanks guys. Have it all under control now.
  18. TRUBLU
    TRUBLU New Member
    Ok, so there was a slight bit of confusion as to what I need. Now I know I don't need to the strut mounts at all which I got from Brian. I need these....which I thought were tophats.
    Need them to suit springs from an 01 Impreza RS....I believe WRX springs will work fine. My car is up in the air at the moment so the sooner someone can get me these the sooner I can hit the road again.
  19. dman
    dman New Member
    Its call upper spring seat. Are your springs tapered on top or not? I have two of these from a legacy, it has non-tapered springs.
    Where are you anyway?
  20. TRUBLU
    TRUBLU New Member
    the new springs are tapered. The springs and struts are from an Impreza. So the upper spring seat I need is from an Impreza also. The ones from my Legacy Outback will definetly not fit.
    I'm in Duluth.
    I was told that I would need strut mounts. I'm not sure why I would need these.
  21. Grayguy
    Grayguy Well-Known Member
    Hey, I have all the struts/springs/tophats from an 01' 2.5RS. I am using the springs out of them, but if you want/need anythign else from them, just let me know.
  22. TRUBLU
    TRUBLU New Member
    are you using the upper spring perches??? if not! I'll certainly lighten your load...if you are...oh well.
    Although I'm guessing you are if you are using the springs. :(
  23. Grayguy
    Ummm, yeah, I'm pretty sure I did the install wrong on my car, cause the springs are in, but I'm still on the Legacy perches...this coudl be bad?
  24. TRUBLU
    TRUBLU New Member
    Have you tried driving it since the install? Not sure if you did that before or after you "immobilised" the car...for lack of a better term
  25. Grayguy
    No, i haven't driven it yet. I'm on Eibach Impreza springs, and everything else is all stock legacy...
  26. TRUBLU
    TRUBLU New Member
    If I remember correctly, you may be just fine. Do you recall if the springs were tapered or not? If the springs were tapered you will definetly need them. If they are not tapered springs then they will not fit.
    I can have a set of those here by Friday but I really need to have the car running ASAP....like today if possible. But if you need them...you need them LOL
    Just let me know if I can come up and get them dude.
    715 309 8559.
    Ray.
  27. TRUBLU
    TRUBLU New Member
    Still in urgent need guys.
  28. ShortytheFirefighter
    D'oh! I'll see if any of the guys in the shop have any laying around and shoot you a PM.
  29. TRUBLU
    TRUBLU New Member
    Man, if they do then I will be so thankful!....think you can score the bolts the keeps everything on top of the strut also? Just be ten times easier if can put them altogether instead of having to take the stock ones apart just to get that bolt LOL
  30. prezawagon
    prezawagon Well-Known Member
    Do you mean the nuts that thread onto the top of the strut? I've got an extra set of those.
  31. TRUBLU
    TRUBLU New Member
    Yup, them ones. Where are you located?
  32. subaruguy5
    subaruguy5 BANNED
    i have one from a 04 wrx sti i used to have, intersetd?
  33. TRUBLU
    TRUBLU New Member
    thanks for the offer but I only need fronts. do appreciate the thought though man!
