Welders
Discussion in 'Off-Topic' started by subaru4, Jan 31, 2008.
  1. subaru4
    subaru4 New Member
    I am looking at maybe getting a wire feed welder with shielding gas. What do you guys recommend? That is not too expensive.
  2. AWDimprezaL
    craftsman makes cheap welders that are pretty durable.
  3. fobiawrx
    fobiawrx Fabiola
    millermatic line of stuff is what i would get.
  4. gran0393
    gran0393 Well-Known Member
    go miller
  5. hofit
    hofit Well-Known Member
    I have a Hobart and it's worked well for me. Easy to use too.
  6. Shibbs
    Millermatic. Great stuff.
  7. Grayguy
    Grayguy Well-Known Member
    millermatic, the biggest one you can afford.
  8. predavore
    predavore Well-Known Member
    I can't afford the small one.
  9. LegacyPGT
    LegacyPGT Well-Known Member
    I have a Hobart 110. Its not too expensive and works great. Go to toll welding and you can try them out.
  10. driftin240
    driftin240 Well-Known Member
    I'll second the Craftsman, but Lincoln makes some reliable welders also.
    I have a Lincoln, as does 3rik's dad.
  11. Jackstand
    Jackstand Well-Known Member
    I have the same one
  12. subaru4
    subaru4 New Member
    How well does it weld?
  13. TSTRBOY2004
    the question isnt so much the welder's ability for a general welder but the person's ability...
  14. subaru4
    subaru4 New Member
    I have had some time to practice at school which I have been doing for 3 years now.
  15. subaru4
    subaru4 New Member
    I also need to find a place that I can get to roll some sheet metal.
  16. Ej22TIM
    Ej22TIM Well-Known Member
    what are your plans for using the welder? what are u making?
    if you say you are making a chopper I will puke in an envelope and send it to you via usps.
  17. Speedemon
    Speedemon Well-Known Member
    we need to know this...and how thick of metal do you plan to weld. Size does matter...
  18. subaru4
    subaru4 New Member
    If I was to make a bike it would not be a chopper. I am starting to think I might just rent one from Toll in St. Paul. I need it for some work on a car. I am not sure how thick the metal is going to be.
