Welding place
Discussion in 'General Subaru Discussion' started by 03subyR, Apr 14, 2010.
  1. 03subyR
    03subyR Well-Known Member
    Does anybody know a good place to weld cast aluminum?
    Thanks,
    Max
  2. TSTRBOY2004
    what is it?
  3. flstffxe
    flstffxe Well-Known Member
    In know people in the north metro, but I bet you would like some one closer to Shakopee.
  4. 03subyR
    This differential carrier
  5. 03subyR
    I would not mind driving.
  6. Shibbs
    JB Weld?
  7. Vector
    Vector Rally Organizer
    Cast Aluminum is going to very difficult to weld effectively. You're going to have to find someone with a lot of experience and a nice powerful welder.
  8. 03subyR
    I was afraid of that answer. :(
  9. carl
    wonder if whiskers could do it. but he's leaving for Olympus testing tomorrow
  10. flstffxe
    You have a PM on its way.
  11. piddster
    Welding cast aluminum is more about setting up the welder properly than power itself. A Syncrowave 200 can weld some decent cast aluminum. Balance control makes or breaks it.
  12. 03subyR
    It not just welding itself the arm is currently supported by a brace I want to secure it by welding around the cracked part.
  13. seal
    seal Member
    can you get it out of the car,do you want it tig or mig welded
  14. 03subyR
    I will be removing it from the car next week and I think I found a replacement carrier so I might not need to weld it anymore. Hopefully the deal comes through. Thanks for all replies.
  15. TSTRBOY2004
    my teacher just welded a cast aluminum transmission... it takes a special rod and lots of preparation work before welding to get all the impurities out... I would say at a minimum you would have 2-3hrs of labor time to have it done right... it would need to be off the car too... the real issue with cast aluminum is you dont know the mix that was used.. it is handfuls of stuff thrown in till they get the mix close enough.... being a late model car it may be a lot better mix of stuff then older cast material...
    I have a TiG here and would be willing to think about it.. but as has been stated... it may be better for a welder that has lots of experience... expect to drop it and leave it for a few days...
    ###EDIT
    just saw your post above... well if you do get another one drop the old one too me and I will try to weld it and see.. then you'd have a spare
