went to clean cai filter and was horrified
Discussion in 'Photo & Video Gallery' started by stangguy, May 19, 2009.
  1. stangguy
    stangguy Active Member
    Off my 05 STI. First time pulling off filter.
    I hate for this to be my first post but I couldn't believe what I saw...
    Any suggestions at what I do to check for motor damage?
  2. sickwagon04
    sickwagon04 Active Member
    seriously? it melted??? what brand filter is that, FYI for everyone to stay away from that one...
  3. stangguy
    no it was cut
  4. blackozone
    So you cut the center of it out or someone else did?
  5. G_2.5rs
    G_2.5rs Well-Known Member
    to me, it looks more like the cover came off and thats the glue used to hold it together...happend to my bro's cheap ebay filter....lol..
  6. stangguy
    someone else did. Hence the horrification. But I guess I'm also an idiot for assuming that someone wouldn't do that to an air filter and not pulling it out before I bought the car...?
  7. stangguy
    APS CAI. I thought about that, but it looks like someone took an xacto to it. Maybe I'm wrong..
  8. Turb0x3r
    Turb0x3r New Member
    oh wow that sucks. I have a APS short ram system and never had that kind of problem.. 33,700, *knocks on wood*
  9. wall of tvs
    Probably. My APS had a K&N filter on it.
    The previous owner needs a gigantic bitch slap, methinks. :eek4:
  10. Turb0x3r
    Turb0x3r New Member
    K&N filter here too
  11. carl
    wow, that's something else
  12. blackozone
    MOAR AIRFLOW!!!! Whoosh!!
  13. kvang
    kvang Well-Known Member
    This also happened to an old vehicle of mine. Check the turbo inlet pipe for the carnage if anything is stuck in there.
  14. predavore
    predavore Well-Known Member
    Ooops...
  15. stangguy
    I did. MAF sensor looked fine. No scrapes in the pipe. No black top in the fenderwell.. Anyone think there is a hole underneath the cap like this? My guess would be no.
  16. Michael48
    Michael48 Member
    As long as you've stayed of gravel roads you should be fine :eek:
  17. StatGSR
    StatGSR Well-Known Member
    i remember buying an ebay intake for my integra once (to try and customize for use with a stock airbox) and the filter that came with it was just like that, except it atleast had a metal mesh over the end of it haha.
  18. sickwagon04
    i hope your lucky and didnt get any damage. i know a guy in eagan that could look at it maybe if you want.
  19. stangguy
    It's going into RS this week (new clutch) and I'm debating whether to have them change the plugs and do a comp test at the same time. Anyone else have any suggestions as to what else to look for?
  20. idget
    check the turbo for fod
  21. piddster
    If that used to have the metal end cap, I don't see how that piece itself could cause damage.
    The only thing is other bits tearing up the compressor wheel. Even if it has a little damage, as long as it still functions, let it rock until you can/want to get something else.
  22. WRX1
    Motor damage is the least of your worries. You turbo will be spinning at over 40k rpm at full boost, before anything makes it to the motor, it has to make it through the spinning turbo AND intercooler core.
