whats a good set of 03 wrx endlinks
Discussion in 'Modifications And Maintenance' started by wrxjoe, Jun 28, 2007.
  1. wrxjoe
    wrxjoe Well-Known Member
    Duluth, dealing car crack
    Well my problems with endlinks aren't as severe as 83projectbrat's (broken endlink WTF) but mine do clunk around and I know they need to be replace so what is a good/ hopefully cheaper set of front and rear endlinks? I was going to get them from importimage but I would like to order in the next couple days here
  2. ShortytheFirefighter
    Kartboy endlinks FTMFW. You can get a set of front and rear together new for 180 shipped, or look for used sets. They go quick, but I got my rears for 50 bucks shipped.
  3. wrxjoe
    zak, did you tell me to stay away from kartboy? or was that another brand?
  4. ShortytheFirefighter
    I think Whiteline endlinks were the ones to stay away from. Great bars, not so good on the endlinks.
  5. Deride
    I have kartboys, get something without pillowball with replaceable bushings like kartboy/whiteline.
  6. ShortytheFirefighter
    IIRC the issue with the Whitelines was that they aren't as beefy as the Kartboys, they're a different design much like the Forester (once again, IIRC. I'll have to check the parts catalog) in that they're a single metal wire (if you see one you'll see what I mean) wrapped around both bushings, where as the Kartboys are a single chunk of aluminum. And the rebuildability of the Kartboys is a great asset.
  7. wrxjoe
    i know whiteline makes some crappy endlinks but they have nice ones too
  8. SLoBaru
    SLoBaru Well-Known Member
    right of pothole
    Whiteline has the wussy looking thick wire formed ones, and the Heavy Duty version which are solid aluminum.
    That said, I do believe KartBoy's are cheaper.
  9. ShortytheFirefighter
    Yeah, I was just going through their site and I can't find the wire formed ones, but the heavy duty ones are still up. Still, you can't go wrong with the Kartboy links.
  10. wrxjoe
    just ordered them. Thanks guys!
  11. mlgez
    mlgez Well-Known Member
    Around
    Whiteline also has some adjustable sets that I am looking at.
  12. Bullwinkle
    Saint Paul
    Yeah. Kartboy rears are very nice. Adjustable front's are much easier to install.
  13. silver03
    MN Bugeye Mafia #300
    I've been real pleased with my Helix endlinks.
  14. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
    you gyys are thinking of whiteline endlinks they have not sold in 5 years (which I used to have on my yellow car)
    The newer Whiteline heavy duty endlinks are what I run and are very good. They have urethane bushings instead of pillowball joints so they are slightly different than helix, pretty much the same as kartboy.
    Best endlinks for performance/money are helix though, better pillowball design, lighter, no clunk. You just have to live with the purpleness of them
    the spacers keep it from clunking and the joint is very nice. I dont think there is much of if any difference between the kartboys and the Whiteline HD's. All whiteline endlinks currently sold are the heavy dutys, the wire looking ones were discontinued.
  15. speedyham
    speedyham Well-Known Member
    Hastings, MN
    What's wrong with purple?
    <- has helix front and rear endlinks. :)
  16. stoooo
    stoooo Well-Known Member
    North Yorkshire, UK
    Nothing a can of spray paint can't fix.
    Stuart.
  17. Nuke
    Saint Paul
    purple on my car?
    that's like pink rims on a yellow bugeye man.
  18. Hallywood
    Hallywood Well-Known Member
    Bloomington MN
    oohh you so funny Nuke
  19. Chin
    Chin Well-Known Member
    Savage
    Ok, so I am lazy... Anyone know of adjustables? I could look, but Zak and Shane do all that anyway.... :p I am having problems with preload on my stockies and I am concerned that a non-adjustable may not relieve the issue... I suspect this is adding to my snap oversteer issue. :(
  20. stoooo
    North Yorkshire, UK
    The Poltec ones look nice - http://poltec.us/products/subaru/suspension/front_end_links/front_suspension.htm
    Hotchkis has some, too, but I don't know if you're looking for ones for the RS or the STi - http://www.hotchkis.net/
    Stuart.
  21. Steve in Minnesota
    Steve in Minnesota Well-Known Member
    Rochester
    I had Helix on the front and rear of my car on Helix sway bars and destroyed the front set and got tired of the clunking like crazy on the rears.
    Right now I'm running Kartboy on the rear and stockers on the front but I need to get a set of Kartboy's for the front.
    Steve
  22. stoooo
    North Yorkshire, UK
    Hmmm, that's unfortunate. I'm currently trying to decide between the Helix ones and the Perrin ones since we found out that you don't actually have to stick with poly bushed ones in ST* classes.
    Stuart.
  23. speedyham
    Hastings, MN
    Paint weighs too much. :laugh:
  24. stoooo
    North Yorkshire, UK
    Self delusion, then ? That way they come in any colour you want.
    Hang on, I thought you were trying to find ways to bump up the weight on your car. You should spray yours with lead paint to further increase the effect.
    Stuart.
