whats so specail here?
Discussion in 'Photo & Video Gallery' started by Dynapar, Apr 22, 2006.
  1. Dynapar
    Orono, MN
    whats so special here?
    i found this picture floating around on teh intrawebz.
    this is VERY cool, do you know why?
  2. 95lwrx
    95lwrx Well-Known Member
    brainerd
    22b i assume
  3. wrxpeed
    wrxpeed CobraPeed
    Maple Grove
    engine code = ej22
    chassis = GC8
    22B
  4. Dynapar
    Orono, MN
    "EJ22G" -----> jumping jesus on a pogo stick!
  5. 95lwrx
    brainerd
    ya lost me, i know most g motors are early wrx or liberty motors, and closed deck, (if i only remembered how to decipher the engine number on the tags, that one number tells you everything about the car, that's how i found out exactly what my front clip was)
  6. Dynapar
    Orono, MN
    ^since i lost ya i will explian. you have a ej20g, which is a closed deck 2.0l. the car picure above has a ej22g. which is a 2.2l engine that was made from e ej20g, so it keeps the G on it. it is not a legacy turbo motor becuase that is a ej22t.
    so what car did they take the ej20g and bore it out to 2.2l thus making a the ej22g? -------------------> only the Subaru Evar.
  7. 95lwrx
    brainerd
    22b right, it's gotta be it
  8. Dynapar
    Orono, MN
    yep, best subaru ever. (imo)
  9. 95lwrx
    brainerd
    ^+11111111 i was right the first time, then you went and got me all confused:???: the 22b kicks arse:biggrin:
  10. John16V
    John16V Well-Known Member
    I am going to print the pic and paste it onto my vin....yeah baby
  11. Chux
    Independence, MN
    woa woa woa......I always thought the 22b got it's name because the motor was the EJ22b
  12. Natural2JZ
    Natural2JZ Well-Known Member
    Minneapolis, MN
    lol i thought it was cause it is a gc8 and it had fugi on it...
  13. Chux
    Independence, MN
    all subaru's, since the 360 of the 1960s, have been a product of FHI
  14. LVT
    LVT Well-Known Member
    t3h f4sT
    GC would indicate that it's a sedan though.....M is coupe
  15. piddster
    Boostonia
    Taken from bbs.legacycentral.org :
    "Jesus,
    Not this again. The G is part of the applied engine code. The complete engine code is actually 10 alpha numeric letters/numbers designating everything about the engine and even a few things about the trim level of the car.
    The 5 place that the G, T, or E holds is the division of fuel delivery. A G designates a DOHC MPFI Turbo engine. The E stands for SOHC MPFI engine and the T stands for SOHC MPFI turbo engine. As the owners of turbo legacies have stated, the metal plate on the driver's side strut tower explicitly says EJ22T on it.
    And as for the old 22B debate, I actually found an owner of a 22B in the UK who had taken apart his engine and rebuilt it. The 22B is cast without oil squirters and is a phase II block with the thrust bearing moved from center to the end like all the other phase II blocks. Our 2.2l turbo block is the daddy of the 22b's block, not the same block..."
    -Matt Monson
  16. Dynapar
    Orono, MN
    ^^ good info.
    i have heard a couple rumors as to the origins of 22B.
    1. 22b --> 2.2l engine w/ bilstien suspension.
    2. 22b --> in hexidecimal or some other on base 10 = 555.
