wheel clearance and offsets
Discussion in 'General Subaru Discussion' started by scrltspedstr, Apr 17, 2011.
  1. scrltspedstr
    scrltspedstr Well-Known Member
    hey so i dont know much of anything about wheels and junk.
    i have an 04 wrx stock brakes i believe.
    i dont really know what offset the wheels i have are (is it listed on them?) they are 17s
    i am looking at buying a set of 17 x 7.5 with an offset of 32
  2. xveganxcowboyx
    Play with this. http://www.1010tires.com/wheeloffsetcalculator.asp
    Those wheels will stick out about an inch and a half more than your stock wheels. On a sedan with narrowish tires and some camber it may be doable, but that is a pretty low offset for a WRX.
  3. silver03
    I have 17" wheels with a +38 on one of our kids cars...thats as low as I would consider going.
  4. scrltspedstr
    so i should pass on trying a 225 45 17 tire on a set of audi 17 x 75 with an offset of 32 (which i would say is a +32)
  5. TMF
    yes, but also consider the additional wear on your wheel bearings (due to the low offset)...some people run their low offset wheels for tons of miles with no issues, while others experience accelerated wear.
  6. scrltspedstr
    so yes pass then?
    i was going to run them as my winter set.
    why is there accelerated wear?
  7. TMF
  8. scrltspedstr
    bummer ill pass then
    too bad they would look nice....green.
    thanks for the tips
  9. dmoo
    dmoo Well-Known Member
    bump for where you are looking at them?
  10. xveganxcowboyx
    While Subarus do seem to have wimpy wheel bearings I would not sweat the offset issue. The difference here is small.
    Unless you are prepared to roll your fenders and *possibly* do extra work for camber I would pass. If you are willing to do that work you may be able to run these without issue. It's a matter of what you are willing to do/sacrifice to make them fit.
  11. TMF
    Yea I didn't mean to talk you out of the wheels, just wanted to mention the potential risks. Like I mentioned before, some people have been running low offset wheels for a long time with no issues.
  12. silver03
    We had to roll the rears with the +38's.
  13. WREX
    WREX Member
    I had to roll my rears with 7.5 wide wheel and a 40 offset. Probably cuz I was squeezing a 245 tire on there too.
  14. xveganxcowboyx
    How wide and what size tires? This makes a big difference.
    245 may indeed have something to do with it. :) Full roll? What were/are your camber settings and ride height?
  15. silver03
    ^^225/45/17 on the +38
  16. xveganxcowboyx
    Any idea on rim width though?a 7 vs 7.5" wide wheel makes as large of a difference as the offset difference here. He could be looking at 6mm or 12 more with the same tire size and camber settings depending on wheel width. Not trying to be pushy or anything, but that much difference may be the difference between an aggressive roll and needing camber bolts or thinner tires. Since his setup is so borderline I want to get as much relevant info as possible.
