Where can I get my fenders rolled?
Discussion in 'Modifications And Maintenance' started by LeiboSTi, Jan 28, 2007.
  1. LeiboSTi
    LeiboSTi Well-Known Member
    Anyone here have a recommendation on where to go to get my rear fenders rolled?
    Thanks
  2. carl
    we gotta gooooo
    my buddy max can do it (well he'll look at it first and then determine if he wants to do it or not). he works at hypertek area 51
    i will pm you his cell number
  3. Sogonerg
    Sogonerg Anteater
    Earth
    I know a good shop that can repaint your fenders...afterwards...You'll know what I mean...Make sure u got a heated space before u do it.
  4. carl
    we gotta gooooo
    your paint will be fine (although no guarantee - there are too many variables). generally speaking, fender rolling won't damage the paint if done correctly with the proper amount of heat. when we did my 240sx the paint was fine. that was a roll with a pull. pulling is where you can run into body/paint issues but rolling is pretty tame (the wrx rears look kind of tricky to roll though)
  5. hakstern
    hakstern Member
    Willmar
    When you get it heated then rolled, will it cool down quickly?
  6. carl
    we gotta gooooo
    all you do is apply heat to the paint while rolling (with a heatgun) to keep the paint soft so it doesn't crack. can't use too much heat though or you'll burn the paint
  7. hakstern
    hakstern Member
    Willmar
    I may be interested but kinda too cold for me -_-
  8. carl
    we gotta gooooo
    if you take it to max's work (area 51) it will be inside a heated shop :)
  9. hakstern
    hakstern Member
    Willmar
    If you know, PM me on how much your friend is asking to roll each fender/all 4 fenders I might have 2 cars to roll. AREA 51 is locared in Minneapolis???
  10. carl
    we gotta gooooo
    the rate is $45/fender. hypertek is in brooklyn park
