where did all my boost go?
Discussion in 'Modifications And Maintenance' started by Dynapar, Dec 18, 2007.
  1. Dynapar
    I have a question (pobably very n00b like).
    Running a VF-11 and MBC. yesterday i would hit full boost (just under .5 bar) and then prety much as soon as i hit full boost it would drop right back down to 0. whats up with this? is it a MBC thing or does it have to do with the wastegate on the vf-11? is my car just messing with me?
  2. fobiawrx
    fobiawrx Fabiola
    could it be the duck tape that blew away?
  3. bummpy
    bummpy New Member
    all your boost are belong to us?
  4. Bielke55
    Yea duct tape boost leak.
  5. esperunit
    esperunit Well-Known Member
    sounds like the wastegate is blowing open under full boost.
  6. Dynapar
    nah duct tape is still there and holding strong.
    possibly
    hmm.. this sounds logical. any way to fix this?
  7. phi11
  8. esperunit
    tighten the wastegate, but I don't know if the vf11 has an adjustible wastegate arm. Forge might make a wastegate for it, or go external.
    Or perhaps the lines between your mbc and your wastegate are incorrect.
  9. fobiawrx
    fobiawrx Fabiola
    does it hit full boost over and over but drop every time?
  10. AWDimprezaL
    sounds like a boost leak, your hose is probably opening up under pressure and closing when you let off
  11. piddster
    ^ werd.
    I've got an extra vf11 chillen here if you happen to need it.
  12. AWDimprezaL
    Chillaxxin
  13. Dynapar
    hmm interesting.
    Well i wasnt pushing it yesterday, since i had things to do and didnt want to push my DT fix to the limits. I hit .5 bar maybe three times. each time it would hit full boost then drop off to 0. I could still build boost, just not reaching full boost. maybe .2 or .3 bar. let off the gas and try again it would peak then drop off again.
    I will check my hoses.
  14. AWDimprezaL
    yup thats what it sounds like to me!
  15. fobiawrx
    fobiawrx Fabiola
    me too
  16. Dynapar
    it makes sense. I will need to test this theory. probably tommorow, when I have time to fix it, if thats the issue.
    FYI: this thing scoots when its at .5bar.
  17. AWDimprezaL
    well durrr, yes!
  18. Dynapar
    Hoses all seem tight. I am wondering if the BOV is blowing open under full boost. I will need to inspect this next.
  19. Dynapar
    checked my hoses. they all appear to be tight, and secured w/ hose clamps. still losing boost. i wonder if its related to this MBC. i opened it up all the way (0psi) so i will see what happens if the thing isnt doing anything. also as i recall the wastegate was making a good seal on the turbo.
