Where did my boost go?
Discussion in 'Modifications And Maintenance' started by Adam, Sep 27, 2006.
  1. Adam
    Adam Active Member
    Is it possible for 02 wrx to go into "safe mode"? My normal PSI is 14-15 but now my car is only boosting to 5 PSI.... anyone know whats going on
  2. Dream
    What are your mods? Have you done anything to the car recently?
  3. Adam
    Adam Active Member
    I had a short ram intake when it happened but now i switched back to my stock air box. I have a 3" exhaust w/ no cat. I tried disconnecting the battery to reset it but no such luck.
  4. Sogonerg
    Sogonerg Anteater
    You probably have a Leak somewhere...Check your lines, clamps, hoses...etc.
  5. Dream
    Ide say you have a leak somewhere. Go back and check everything over...
  6. Adam
    Adam Active Member
    would i be able to hear a boost leak at all
  7. AWDimprezaL
    Boost solenoid out? doesnt the stock wastegate actuator open at 5-7 psi? could be running off the waste gate
  8. Dynapar
    OEM WRX wasteages open at around 10psi. so at this altitue it should be pushing 6-7psi on wastegate boost. your problem lies elsewhere.
  9. esperunit
    esperunit Well-Known Member
    get a cigarette. Light it. move it around the engine compartment until you see smoke getting sucked into something. There's your vacuum leak.
    note: try to do it right after starting the car so your radiator fan doesn't go on.
  10. Scuba Steve
    lol...car repair 101 for smokers...love it!
    Now I have an excuse to smoke.:marlboro: :cheers:
  11. DISCOPOPE
    DISCOPOPE Well-Known Member
    did you put the maf in backwards?
  12. esperunit
    yeah its one of those "crafty old guy" tricks.
  13. Adam
    Adam Active Member
    Tried the cigarette idea but couldn't find anything. The Maf only fit in one way so i'm assuming it's the right way. any other ideas?
  14. subytek
    subytek Well-Known Member
    Have you played with the stock recirc. valve at all, if so check the bolts and gasket.
  15. WRX1
    What kinda of vaccume are you running at idle??
  16. Adam
    Adam Active Member
    a little over a bar i believe...
